MYGICA MINI DVB-T2 USB STICK (T230C)
And put the new image of you and for my usb tdt (T2) to work, it is necessary to do the steps indicated above, with which this new image does not arrive increased so that it works without doing anything.:(
I have the same problem with Zero 4k and T230c. Hoy did you solved this problem?
Thanks.
Enviado desde mi SM-G975F mediante Tapatalk
I've resolved the problem using openspa. This image have in spa-panel an option to manage dvb usb. It recogniced the tuner and i installed drivers and activate tuner.
It would be great to have this option in Black Hole, but i will use open spa.
How? I'm testing openSpa and i like a lot.. but i want to know how i can make it works in open BH.
Thanks a lot
good evening
on my vu zero kernel 3.13.5 installed latest openspa image and during the configuration, without installing the drivers, the dvb-T2 usb TV eye windows edition h265 HEVC (alias MyGica T230C) has been recognized and fully functional. Now I install Openvix.
I am sorry to point out that blackhole does not give support because I am forced to abandon it. I tried instal manually according to the instructions https://www.linuxtv.org/wiki/index.php/Geniatech_T230C but I failed.
I kindly ask the developers if in the future it is possible to implement this DVB key.
thanks
@vibrena: It doesn't matter it doesn't work in BH!
In other images, you go to driver feeds panel and download the driver for it, or it's mostly installed when you shut down the box->plug in the USB->start the box
many thanks Yoko,
I went to the feeds, but I don't know the driver names can you tell me? and I ask you, if you can say in the forum, which images support it? besides openspa who sees it already installed
thanks
In OBH I do not remember the name of the drivers but I know that it is and it works.
In OPENSPA the driver to be installed (in this image it has already been incorporated and running) is the ct2-dvd-usb-geniatech-t230 (1.0-r1).
Good evening,
my dt2 is from the Geniatech EyeTv lite windows family edision ID 0572: c699 which is installed automatically only from the image OpenSPA, on the other images you indicate does not work with the drivers ct2-dvd-usb-geniatech-t230 ( 1.0-r1) of the Mygica T230C Id old model with ID 0572: c689 and new model with ID 0572: c68a always the latter automatically on Openspa.Then it is not possible to understand which driver variant uses Openspa to be able to install it on the other images. Mygica T230C and EyeTV lite are both from the Geniateck https://www.linuxtv.org/wiki/index.php/Geniatech_T230C.
I ask if anyone knows anything.
Thanks
Openspa worked it out so that the latest version of this usb will work at 100x100, and in fact if you put your image, you don't have to do anything at all for that usb tdt to work great.
In OBH it also works as commented and you have to install the drivers from its section and completely reset the deco, what happens is that sometimes it loses it because it is not completely debugged.
IN BH IT DOES NOT WORK, if the experts give solution to that problem that is already reported.
Good evening,
unfortunately every attempt was not successful, the EyeTv lite does not have the same drivers as the Mygica DVB T230C, in fact the openspa that installs it automatically, in the driver download functions those of Mygica are not installed, but the EyeTv lite works equally. it seems legitimate to ask in the openspa forum what these drivers are. I remind everyone that EyeTV lite vendor is ID 0572: c699, while Mygica T230C ID 0572: c689 and new model ID 0572: c68a.
Thank you for your contribution
