MyMetrix-OpenStore BH 2.0.x
hello,
May I ask a question regarding this skin, how to add the signal info in the classic infobar? tried everything and every part but sometimes green screen, and sometimes it doesn't work, any help?
hello,
just installed in blackhole parts
red button mymetrix/openstore/blackhole part/ ..
Personal installed this skin in BH 2.1.5 image only that it does not appear the picons this picture .... the size of picons are 220x 132 .
Hi, i have OPH and this skin....but in the channel list when i press -> on remote control the bouquet title disappears, exist a plugin or skin part for this "problem"?
There is no support for third-party skins! So, if you intend to use it, do it at your own risk!
Note: Your post it´s too O.T., this is BlackHole international section! Not for Open Blackhole Support.
How can unistall and delete other skin and file ?
You have installed a skin moded for Black Hole not compatible with Open Blackhole.
To uninstall it on Open Blackhole ... Press <MENU> <PLUGINS> <RED KEY> --> navigate to skins and uninstall it if you have it displayed!
If not ... You must do it by hand!
Regarding OBH Support --> Even regarding the same support, i´d like kindly ask you to open a new thread on OBH ... not here!
:thanks:
:thanks:
Open store my metrix is for only BH image?
when i use BH 2.1.7 show this message " not compatible" and i can not active a skin :S
and other, i can't sign up on the open store site...why?
in the BH 2.1.7 with this skin the plugin downalod are divide for category?
thanks
thanks
Not compatible with 2.1.7 it says 2.0.x, so at least BH 2.0.9!
Are you using OBH or BH?
Now OPH
Before 2.1.7
Ah its compatible Max for 2.0.9. BH
Ok
Thanks again
Maybe, compatible! :wallbash:
OPH --> You mean OBH = Open Black Hole 0.1, right?
If this is the case ... Open your threads in the correct section, regarding the Image version you use .... On OBH section for Open Black Hole images, on BH section for Blackhole images!
Thanks
