Is it mounted correctly?Hi
my Ultimo is connected with a NAS and I've some shared dir, one of these is used as HDD replacemente: all is working good but with 1.79 I cannot make Backup 'cause no device is detected.
I'm sure that with previous version backup was performed to shared dir ...
Thanks a lot
cu
Are you talking about Personal backup or full backup?Hi
yes I suppose...
Actually I can register on it as it was my internal HDD, I see shared dir and play all what I want...
cu
That is really strange as it should work.Hi
I cannot use no one of backup methods....
I've 3 shared dir (NFS)
1) Film
2) Hard
3) hdd used as hdd replacement
1 and 2 are visible in Media Player and I can use the file stored on them, 3 is the one on which are stored the file recorded from receiver.
When I try to use BAKUP the error is "No device found.... ", if I use PERSONAL BACKUP it says to setup device first, and when I try
do setup the error is the same, "No device found.... ".
I'm sure that I' ve used the two method 2 or 3 version ago and all was working good.
Thanks a lot
cu
root@vusolo2:~# mount
rootfs on / type rootfs (rw)
ubi0:rootfs on / type ubifs (rw,sync,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=285836k,nr_inodes=71459,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
udev on /dev type tmpfs (rw,relatime,size=2048k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
usbdevfs on /proc/bus/usb type usbfs (rw,relatime)
tmpfs on /var type tmpfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
/dev/disk/by-uuid/08f2f512-d7c5-47cd-ad28-4facf0ba5c27 on /media/usb type ext2 (rw,relatime,barrier=1)
/dev/disk/by-uuid/222a9317-13ec-45e0-8da9-6a3e15d304e0 on /universe type ext2 (rw,relatime,barrier=1)
/dev/disk/by-uuid/7B3B-1D0B on /media/cf type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
djmount on /media/upnp type fuse.djmount (ro,nosuid,nodev,relatime,user_id=0,group_id=0)
automount(pid715) on /autofs type autofs (rw,relatime,fd=4,pgrp=715,timeout=5,minproto=2,maxproto=4,indirect)
//192.168.0.24/Harddisk on /media/net/VUULTIMO type cifs (rw,mand,relatime,sec=ntlm,unc=\192.168.0.24\Harddisk,username=username,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.0.24,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=8192,wsize=8192,actimeo=1)
Yes it workTry to connect via ftp and go media/hdd and try to copy anything you want on it.
Tell me if you can.
Here it is (the HARD shared dir I mentioned the post before is not mounted at the moment..)Try also to give me the output of command mount on telnet.
root@vuultimo:~# mount
/dev/mtdblock2 on /boot type jffs2 (ro,relatime)
nfsd on /proc/fs/nfsd type nfsd (rw,relatime)
automount(pid675) on /autofs type autofs (rw,relatime,fd=4,pgrp=675,timeout=5,minproto=2,maxproto=4,indirect)
192.168.10.2:/film/ on /media/net/FILM type nfs (rw,relatime,vers=3,rsize=8192,wsize=8192,namlen=255,hard,nolock,proto=tcp,port=65535,timeo=70,retrans=3,sec=sys,local_lock=all,addr=192.168.10.2)
192.168.10.2:/ET9000/ on /media/net/HDD type nfs (rw,relatime,vers=3,rsize=8192,wsize=8192,namlen=255,hard,nolock,proto=tcp,port=65535,timeo=70,retrans=3,sec=sys,local_lock=all,addr=192.168.10.2)
root@vuultimo:~#
[global]
load printers = no
guest account = root
log file = /tmp/smb.log
log level = 1
security = share
server string = Vuplus %h network services
workgroup = Vuplus
netbios name = %h
case sensitive=yes
preserve case=yes
short preserve case=yes
socket options = TCP_NODELAY
preferred master = no ;(These stop the machine being master browser, which means that it doesn't waste time there.)
unix extensions = no
[Configuration]
comment = Configuration files - take care!
path = /var
wide links = yes
read only = no
public = yes
guest ok = yes
[Harddisk]
comment = The harddisk
path = /hdd
wide links = yes
read only = no
public = yes
guest ok = yes
Maybe that file is shared from nas trough solo2.Hi
I have not reflash my Ultimo yet, but I've a new fact to tell that may be will be useull. I' m testing Vu+Solo2 and I've shared same dir as Ultimo, on my NAS, for HDD replacement: with Solo2 Personal Backup is working well, but the strange think is that the file related to backup is seen also by Ultimo in the Personal Backup windows .....
Hope this will help you
Thanks
cu
Of course but if the Ultimo does not consider any dir to store backup why iya can see the vbackup from another receiver ? In theory it should not see dire and fileMaybe that file is shared from nas trough solo2.
ahahhaah this will solve all my problem... foreverBe careful not to use solo2 personal backup on ultimo
Hi
I' ve installed 2.0 and as for 1.7.9 backup does not work . All is the same as in the posts in this thread
sigh
cu
