Navi-X fix for beta2
ekke201
Hi installed Navi X on my Solo SE but something went wrong. Now trying to reinstall it without sucess.
How can i clean XBMC from my corrupted NAVI X installation?
Have to install it correct before the fix can be uploaded
2wild2tame
hi shiro
1-i found .xmbc in usr / lib ..is it OK?
2-installed navix but didn't find folder in addons
3-i can access my duo 2 but how can i browse my pc files through xmbc -do i have to mount sthing?
thanls very much for your help
johny4192
This can help someone maybe,
I seen that after navi-x plugin update, folder name changed, so currently is running from
/media/hdd/.xbmc/addons/script.navi-x/
so, in case that your plugin stopped working, have a look on folder path and fix navix.py file in the new directory too.
This worked for me.
