What image do you have installed?
How have you set up your tuners, in the menu?
There are threads, on the forum, that might help, try a forum search for unicable, and other terms, I quickly found this, but it is from some time ago:
I have absolutely no experience with SCR Unicable and their configuration, af LNBster almost 17 years of satellite equipments. Now I'm going to order a new LNB of this kind and partially modify situation to take advantage of Solo4K virtual tuners if used with SCR. This SCR will be used for 13°E...
blackhole-community.com
