New Kodi Post
nay27uk
How do I totally uninstall the Kodie Plugin and get it off the box completely???
The KODI that comes built in to OpenBlackHole has to many problems.
First it is an outdated KODI 16.1.
Second it opens sometimes in the corner of the screen.
Third it is a bog standard version of KODI I.E it has no build on it.
Forth Trying to install any build like say The Beast, AiApolo, Pulse etc etc (always starts fine but then we get this message, (no space left on this device).
Why include KODI if on a VU+ Solo SE V2 there is not enough space to install a proper build of KODI on KODI on this system?????
I want to fully remove KODI from OpenBlackHole as it serves no purpose at all on this box when you cant install a proper Build.
HOW DO I GET IT COMPLETELY OFF THE VU+ Solo SE box using OpenBlackHole???????????????????????
The KODI plugin needs
1) - Kodi is not installed in OpenBH 06 ( by default ).
2) - Make a fresh install of Open BlackHole 06, just no push in Black Hole Speed-Up, and you have KODI away from your STB.
Already did a fresh install i downloaded the blooming thing had black hole on first downloaded openblack hole
Ready did a fresh install i hads blackhole on before i downloaded open blackhole and transfered to usb turned the box of, put usb stick in turned box on, waited till lightswhere flashing, turned box off, took out the usb stick, restarted/powered up the box. Kodi is in the plugin manager
By the way it was OpenBlackHole 0.6 I downloaded and RE FLASHED especially for the VU+ Solo SE and WHEN FLASHED from ordinary Black Hole if you have the box go do this then look in Plugins of OpenBlackHole it is listed there KODI Launcher.
I even did a factory RESET from the normal Black Hole before flashing the OpenBlackHole.
Wich version of Open Black Hole, mate?
You must be joking.
Due a fresh install .... Dont´t flash a backup downloaded from other sites, and claim here for support.
OPEN BLACK HOLE 06 doesn't contain KODI installed in image.
You must be joking.
right how can I take a screen shot of the box OpenBlackHole version and save it to my computer to prove it
Now you can try telling me that KODI is not included in OpenBlackHole 0.6
This is doing a full RE-FLASH on the box, I have had Dream Boxes and Linux Sat/Virgin Boxes since DreamBox 7020 so I have been doing all this for a very long time.
OpenBlackHole 0.6 most definitely has in the plugins a KODI entry. Prove me wrong.
Make a screenshot of BlackHole SpeedUp Menu, ok?
You are completely wrong, and i know this image very well ...
KODI is only avaiable in image if you has enabled it on BH-Speed UP ...
Sorry, but ... or you are using a backup image or you have enabled it.
OK?
upload_2017-2-21_18-54-0.pngupload_2017-2-21_18-56-18.pngupload_2017-2-21_18-58-14.png
Can you please post a screen like mine on the middle? or the second one " Open Black Hole Speed Up " Menu.
Press twice the blue button. to obtain this screen.
You are wrong, you are using a backup or re-loading your settings.
Remove any other USB device and HDD and carry out a fresh install.
1} If in flash is instaled new version OBH is no possible have KOdi becouse:
image OBH have 67mb and is no possible include to he kodu who have around 50mb
2} Kodi create hiden folder on hdd or usb and maybe you see. he after reboot image ?
OK I had enabled it in "speed up" during install, what a silly mistake (A sub Menu called Speed Up making you think stuff in it will speed the box up), but even so it still enforces what I said "that open Black hole comes with kodi built in" (you people here point blank Refuted that it has Kodi, only when I said it did and showed you screen captures did you change your minds and say "YEAH BUT" only if you enable it in SpeedUp) even if it is hidden in a submenu called "Speed Up" when nothing inside the sub menu called "Speed Up" is anything to do with making the box faster, OpenBlackHole clearly comes with Kodi.
You have no reason.
Do you see kodi in my previous screen shots?
Do you see any sign of kodi in this one?
And in this one?
I don´t know what you are trying to prove. But indeed you are completely wrong.
It is not built in, when you enable it YOU download it, hence the reason we all said it is not in the build, you can download many plugins or extensions as you see fit but they are not built in.
