New Skins BH 3.0.5
Hello Mx,
I do not have newcamd installed on my tuner, so newcamd can not be a source of a problem with my tuner.
Below you can find another crash-log created some hours later then the first one.
Please consider, I am using "worlds" in UNIVERSE and a USB DVB-T tuner.
Maybe it was a reason od GS's?
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Wed Dec 27 23:17:15 2017</crashdate>
<compiledate>Nov 1 2017</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>2017-10-23</sourcedate>
<branch>master</branch>
<rev>2.1.4-244-gf87099d</rev>
<version>3.0.0</version>
</enigma2>
<image>
<kernelcmdline>bmem=118M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201710181538
</imageversion>
<imageissue>
<![CDATA[
BlackHole 3.0.4 %h
</imageissue>
</image>
<software>
<enigma2software>
<![CDATA[
enigma2-meta - experimental-git20121128-r159-bh65-bsp13
enigma2-plugins-meta - experimental-git20110215-r14-bh2
</enigma2software>
<dreamboxsoftware>
<![CDATA[
</dreamboxsoftware>
<gstreamersoftware>
<![CDATA[
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
back to default Enigma2 Translation for AutoShutDown Setup
[AutoShutDown] fallback to default Enigma2 Translation for AutoShutDown
remove DVI-PC because it does not exist.
set HDMI Colorspace : Edid(Auto)
hotplug on DVI
set Videomode DVI 1080i 50Hz
set aspect, policy, policy2, wss 16:9 panscan letterbox auto
resolve: resolve ${datadir}/enigma2/
resolve: -> /usr/share/enigma2/
[CI_Assignment] activating ci configs:
[CI_Activate] FOUND 2 CI Slots
resolve: resolve ${sysconfdir}/enigma2/ci
resolve: -> /etc/enigma2/ci
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
[CI_Activate_Config_CI1] no config file found
[CI_Activate_Config_CI1] error parsing xml...
starting BlackHoleapi handler
starting hotplug handler
add device sda to bdpoll current state: medium inserted
It's now Wed Dec 27 23:16:54 2017
[timer.py] next activation: 1514413114 (in 99297 ms)
[TIMER] record time changed, start prepare is now: Thu Dec 28 04:59:40 2017
sanitycheck
check
checkTimerlist
recording service: 1:0:1:3D5F:2C88:13E:820000:0:0:0:
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
RECORD service event 14
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x7315c5b0>
ProcessRepeated
next real activation is Thu Dec 28 04:59:40 2017
[timer.py] next activation: 1514413114 (in 99272 ms)
[TIMER] record time changed, start prepare is now: Thu Dec 28 16:14:40 2017
sanitycheck
check
checkTimerlist
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x7315c630>
ProcessRepeated
[timer.py] next activation: 1514413114 (in 99247 ms)
[TIMER] record time changed, start prepare is now: Fri Dec 29 16:09:40 2017
sanitycheck
check
checkTimerlist
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x7315c650>
ProcessRepeated
[timer.py] next activation: 1514413114 (in 99203 ms)
[TIMER] record time changed, start prepare is now: Sat Dec 30 08:29:40 2017
sanitycheck
check
checkTimerlist
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
recording service: 1:0:19:2B8E:3F2:1:C00000:0:0:0:
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x7315c690>
ProcessRepeated
localrepeatedbegindate: Sat Dec 30 08:30:00 2017
localbegin: Sat Dec 30 08:30:00 2017
localend: Sat Dec 30 09:00:00 2017
localnow: Wed Dec 27 23:16:55 2017
Day: 5
ProcessRepeated result
[timer.py] next activation: 1514413114 (in 99142 ms)
[TIMER] record time changed, start prepare is now: Mon Jan 1 20:59:40 2018
sanitycheck
check
checkTimerlist
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
recording service: 1:0:1:32DF:190:13E:820000:0:0:0:
record: 0
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
[Timer] Record <RecordTimer.RecordTimerEntry object at 0x7315c850>
ProcessRepeated
localrepeatedbegindate: Mon Jan 1 21:00:00 2018
localbegin: Mon Jan 1 21:00:00 2018
localend: Mon Jan 1 22:01:00 2018
Day: 0
[timer.py] next activation: 1514413114 (in 99113 ms)
[timer.py] next activation: 1514413114 (in 99110 ms)
[CrossEPG_Auto] AutoStart Enabled
[CrossEPG_Auto] Schedule Enabled at Wed Dec 27 23:16:54 2017
[CrossEPG_Auto] Time set to Thu Dec 28 09:10:00 2017 (now=Wed Dec 27 23:16:54 2017)
[AutoShutDown] start....
Looking for embedded skin
port changed to DVI
mode changed to 1080i
default ('1080i', 'default')
preferedmodes ['720p', '576p', '480p', '576i', '480i', ('1080i', 'default')]
[EPGC] setCacheFile read/write epg data from/to '/media/usb/epg.dat'
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
setValue 80
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
Setvolume: 80 80 (raw)
Setvolume: 13 13 (-1db)
allocating new converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
warning, skin is missing element button_cex in <class 'Blackhole.BhEI.Nab_ExtraInfobar'>
RemovePopup, id = ZapError
main thread is non-idle! display spinner!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
warning, skin is missing element Universe in <class 'Screens.InfoBar.InfoBar'>
reused converter!
reused converter!
playing service..
[EPGC] 54809 events read from /media/usb/epg.dat
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 15863840 bytes for cache used
not pauseable.
allocate channel.. 2af8:013e
Slot 0, score 10004
Slot 1, score 10004
Slot 2, score 0
opening frontend 0
[eDVBCAService] new channel 0x1673b30!
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 1 Freq 10719000 Pol 1 SR 27500000 INV 2 FEC 3 orbpos 130 system 1 modulation 2 pilot 2, rolloff 2
tuning to 969 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:1138:2AF8:13E:820000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] set static current limiting
set sequence pos 3
set sequence pos 4
[SEC] setVoltage 1
[SEC] sleep 200ms
[ePopen] command: route -n | grep eth0
[eConsoleAppContainer] Starting /bin/sh
poll: unhandled POLLERR/HUP/NVAL for fd 34(16)
poll: unhandled POLLERR/HUP/NVAL for fd 36(16)
poll: unhandled POLLERR/HUP/NVAL for fd 38(17)
[SEC] invalidate current switch params
[SEC] sendDiseqc: e00000(DiSEqC reset)
[SEC] sleep 50ms
0.0.0.0
169.254
192.168
nameservers: [[192, 168, 1, 1]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 7], 'up': True, 'dns-nameservers': False, 'mac': '00:1d:ec:02:63:61', 'dhcp': True, 'bcast': [192, 168, 1, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1]}}
SerienRecorder plugin not found
EPG Refresh Plugin not found
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
[OpenWebif] no plugins to load
[OpenWebif] started on 80
poll: unhandled POLLERR/HUP/NVAL for fd 37(16)
[SEC] sendDiseqc: e00003(DiSEqC peripherial power on)
[SEC] sleep 150ms
[SEC] sendDiseqc: e01038f0
[SEC] sleep 50ms
set sequence pos 3
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion off, m_tuning 1
[SEC] set dynamic current limiting
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1673b30 running
[eDVBLocalTimerHandler] channel 0x1673b30 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x1673b30 running
stop release channel timer
0012: 4e 11 38 00 00 00
mask: ff ff ff 00 00 00
[EPGC] next update in 2 sec
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (00a7), and 1 audio stream(s) (006d), and the pcr pid is 00a7, and the text pid is ffffffff
allocate demux
disable teletext subtitles
PES filter: DMX_SET_PES_FILTER - Invalid argument
decoder state: play, vpid=167, apid=109
DMX_SET_PES_FILTER(0xa7) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x6d) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 1 - ok
DMX_SET_PES_FILTER(0xa7) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
not pauseable.
[AutoRes] service changed
+ 1/1 TID 00
done!
PATready
use pmtpid 03f0 for service_id 1138
03f0: 02 11 38 00 00 00
doing version filtering
0000: 00 00 00 2b 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[eDVBLocalTimerHandler] diff is -1
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] update RTC
[eDVBLocalTimerHandler] time update to 23:17:02
[eDVBLocalTimerHandler] m_time_difference is -1
[eDVBLocalTimerHandler] set Linux Time
[AutoRes] got event evVideoProgressiveChanged
+ 1/1 TID 02
done!
have 1 video stream(s) (00a7), and 2 audio stream(s) (006d, 006e), and the pcr pid is 00a7, and the text pid is ffffffff
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
[eDVBCAService] new service 1:0:1:1138:2AF8:13E:820000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:1138:2AF8:13E:820000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
03f0: 02 11 38 0d 00 00
mask: ff ff ff 3f 00 00
+- 1/2 TID 4e
[AutoRes] determineContent
[AutoRes] switch deinterlacer mode to auto
[AutoRes] new content is 1920x1080p25
[AutoRes] determined videomode 1080i
++ 2/2 TID 4e
done!
0012: 4e 11 38 15 00 00
sdt update done!
[EPGC] start caching events(1514413023)
action -> InfobarExtensions DeliteBpshow
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
action -> OkCancelActions ok
[EPGC] nownext finished(1514413033)
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Blackhole/BhBlue.py", line 234, in keyOk
AttributeError: 'DeliteBluePanel' object has no attribute 'newcamd'
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x71f61198>>,('OkCancelActions', 'ok')) failed)
</enigma2crashlog>
<pythonMD5sum>
<![CDATA[
b030aa151717e9f2e4f4e7f13eaa8715 /usr/lib/enigma2/python/Plugins/Extensions/MovieSearch/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MovieSearch/__init__.py
e97d446503e018c82f134f9c095681cd /usr/lib/enigma2/python/Plugins/Extensions/MovieCut/plugin.py
4957353b18d82e36ac41a62e111d70fd /usr/lib/enigma2/python/Plugins/Extensions/MovieCut/__init__.py
7378e8372388413ed1302d28bb76e5a9 /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/CutListEditor/__init__.py
c1c47f9577cda15851da5ac11d01c5cd /usr/lib/enigma2/python/Plugins/Extensions/TagEditor/plugin.py
057efd7a78c90a58a8962526f2009b03 /usr/lib/enigma2/python/Plugins/Extensions/TagEditor/__init__.py
0734c5f293b97666fe78a8dabb913307 /usr/lib/enigma2/python/Plugins/Extensions/MovieRetitle/plugin.py
0adf8b6bf3287f3693c7a82495f55231 /usr/lib/enigma2/python/Plugins/Extensions/MovieRetitle/__init__.py
1faf893734903973d274870046e962c7 /usr/lib/enigma2/python/Plugins/Extensions/MovieTagger/plugin.py
194d4a57b5c2294fb555a1ab25bebfa5 /usr/lib/enigma2/python/Plugins/Extensions/MovieTagger/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/__init__.py
c8ef66b79e32aa1abdfd1d1034b4e6fd /usr/lib/enigma2/python/Plugins/Extensions/DLNABrowser/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/__init__.py
2ae0e1640ea4267540f2922afab4eb5b /usr/lib/enigma2/python/Plugins/Extensions/MediaScanner/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFullBackup/__init__.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/__init__.py
360fa49bfd3d8517529ecfff44ba7347 /usr/lib/enigma2/python/Plugins/Extensions/SatipClient/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/__init__.py
325cbbddf515e2c0b07eb8773a19d9f8 /usr/lib/enigma2/python/Plugins/Extensions/StreamTV/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/__init__.py
d1e9446c69b2747c127cf37efe03cf7b /usr/lib/enigma2/python/Plugins/Extensions/AddStreamUrl/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/__init__.py
7bf99b4b797254f0536fbd08fef66f6f /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/settings.py
3d0b90bf193c5e092ed0f0cacaab7161 /usr/lib/enigma2/python/Plugins/Extensions/MediaPlayer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhPersonalBackup/__init__.py
38ed187e5d17b3e3ff8e8dd57c30ad89 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/GraphMultiEpg.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/__init__.py
e495f59341b9d41c810732b50b001dc1 /usr/lib/enigma2/python/Plugins/Extensions/GraphMultiEPG/plugin.py
e3f2b4c944c3506d87e4a2fed889e7ed /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/__init__.py
bd5c5ee5a860cd29927ac464bc974356 /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/FTPDownloader.py
ef3ac8110d407d6e2b486094762ab757 /usr/lib/enigma2/python/Plugins/Extensions/RemoteChannelStreamConverter/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/__init__.py
5e0679daa876a928523947d805c93984 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/httpserver.py
0fa63c0a511be87ea42c60af2d9f1ce9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/stream.py
bb6dcb25c5cc0b1e6ee9f00bd7bb6f2a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/AT.py
caaf4889ea3a0ebcad060d41c29b4a22 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/volume.py
e56ee0c02c224d4e45113fb4ca610777 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/owibranding.py
85b7b2780c7e621aedb7d7967d41fb09 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/services.py
185f12163e56e525956e378d17dc90e6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/stream.py
c97e280db47552107c28b3f7ae749f96 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/audiotrack.py
1f8db2f543e40fd4030a1e1d5a415a9a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/control.py
513a9d947f0aaaa2609d29e89dd8c7f6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/message.py
944a281701dc5d34755e93ca1400dde7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/movies.py
7421f5ddf6b7489740567fba367e7712 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/servicelist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/__init__.py
dab24b0addfa25e9f13b8e29764bccf2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/locations.py
51c3852ff517e1e8d7a712b279574ec5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/info.py
8dc4c41a7bb235394ffb7e1dc1ee9b69 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/grab.py
e96c2191ea52666e12ceb876be67614e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/mediaplayer.py
0af930f15ab213aef8ed0927617489e4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/plugins.py
d5d965bd93484d6665c8d917841f5042 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/config.py
d8f2f07b408b48deea4bcbaffd8c6984 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/models/timers.py
31f08a47ac714e3c5b90374b68d24c2a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ER.py
96a04c6daec7bf74e8c016e3acb7dbbb /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/SR.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/__init__.py
71717354feb7304f19d6ee91280a8bb5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/file.py
e91c5b473a99063af96feb82dd16b39c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/external.py
ab56d316fa7fd3748043765857072d28 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/removelocation.py
e8ba59b1c2ecd65905fdb0c5441bc249 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timertogglestatus.py
8bea9e390c2c085ae785a8ba4b257a4c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearchrss.py
c03e87f1e9bcf3a72fca916c3e9524ae /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielisthtml.py
ceb714751a5b385f84f253b4f304419a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerchange.py
bcc662c4e568449a084beeff9f51b04b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerfindfile.py
a5eb48951ef93f36ef6186d91c04c3b3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrlocation.py
3600587d8440b959cfe0e54d29db4599 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tvbrowser.py
12dd1d48dfe46065d27470da359688d4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayeradd.py
b00c13748aee2838f2a9bb39a742b557 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerwrite.py
229e156dfafe688773bc4c17684f59b1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getservices.py
0ac22c77d4f8cc9d48a3bb59881dd363 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerdelete.py
31ecbdc2b5f78bc24ecf4806b896547e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getpid.py
6e38716fdb4c968958b87bfda3b7269b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnext.py
995496cc4cacb18fa9100e31a3299eae /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercmd.py
57a3d9eb201ac52fc0d3bb7dbdd2a822 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/messageanswer.py
42310aff02108b334cbdd4613f427dbf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsearch.py
d27c56dd10989ea3560667a53079c8b7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/parentcontrollist.py
599b67a4eca440a1c3e42c28719b3e1d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/loadepg.py
ec0ab12e9c758df63c53750e92d7701b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/restarttwisted.py
a28f8ddf06d14acd8873fa7d3e3c8ebe /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayercurrent.py
57e73869c4e92615fd31ff72cd7d0630 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistm3u.py
3993c849379edb6f55d64b03121d02b5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerremove.py
4912529a56d4415ff36961543a9cf36f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlistwrite.py
e2314757d8e34cc04290f2886469d769 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservice.py
002bcac41875dbe91a863d543cb27f7a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/currenttime.py
cb9470182d88131346eb1c609e86af6a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getcurrent.py
550021f3b556c709351af8e7e834bea3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/message.py
09f9ce2519438df45a6716fc77137690 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/gettags.py
27a87651ad647a646fb37680898fe52b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/subservices.py
a6e29ddfd96452bb4d01cc036511551f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicesm3u.py
2f1246ab7cbabac1a95d9e07a626fb76 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeradd.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/__init__.py
499ced0f9367d758d351f33f601acf69 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/settings.py
252fd4e97137dde13842cd696b6141b9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerlist.py
a00833274630a0f2789609a891406fc3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviemove.py
e7c99550ae6db37d14ee472634693f9b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/moviedelete.py
0cf3d1763920c1fca3d3abd740c91a5f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getallservices.py
fe0d368ddab30f08ba29608c7beb0619 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/bouquets.py
2c5939a958df78a766168215af506dac /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenow.py
f912a523b9ce4e7d7013c27077345f5f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/tunersignal.py
77be393bd38ce69bd357e92193c7ca35 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/streamsubservices.py
ff720306274188e1645673db00e607a8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnow.py
ddcf39b4e784dd342b4451990b9c87b9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielist.py
92a3d92f352d3ae51d57c644ce8fd7ff /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/recordnow.py
24488cbc297b1c19c593ac234c89f7d2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistreload.py
aeca7b489e9e8cd2e27669a081a8ecd8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movierename.py
f3092f91ac03cdff1989c0e7ad92044d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgsimilar.py
9088777b43d054c15ac99ccf401b529f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/about.py
a81fa689ca74ca29c7194355459830ed /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/deviceinfo.py
a54282f3ccf8330132bb7d3d7facf575 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerload.py
3ad3bacd9ed1a83b2e56d7650da22c2c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/serviceplayable.py
99a569e5edbbdbe0f9c5592bf1f9d060 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/pluginlistread.py
27fbc8f6aed03aeeb74a5b26d723db96 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgbouquet.py
1bfe3db6e9e7f8c4a3d4dad4f153c3dc /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timercleanup.py
0f6026ade756d2bfe2cdd0de56f38594 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timeraddbyeventid.py
f5c1f8403dbd97c6abef0bbf03fb7af8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movietags.py
78fcd06612799c8881a218dec17090d8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getaudiotracks.py
ab7c11797f473b83dde96cccf71a590e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/vol.py
a438688f70887ce7bdff6b87fd398a99 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getipv6.py
a905a8a1623bb03b6b24cc50a5e8c29b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/css.py
e2ebc0006b14eba45eaeb742b4aa621b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/powerstate.py
b832a8be76e31f5d4210403f394b1e4a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/addlocation.py
fe51a249fdd038f36f2339195bceab9a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/saveepg.py
5c62671fe4ee30f78812b9242ef4bfce /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/movielistrss.py
faffc95c7c6e5bdcbd1e3a18f4f6d1fd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/getlocations.py
8cfd199a321a9f96414575ccce2c569c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/servicelistplayable.py
ec8deb76006b69ccf17b848aaa184e46 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgmulti.py
db25fc24124d91ea3b28aa1139280787 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/remotecontrol.py
ac73b23fb5b3981b371106f16af3b309 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/sleeptimer.py
e0833f58cdc46cbbe6e4f24f0f789fb4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/mediaplayerplay.py
026dcd94db027b22f233e5688f4ab6a2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgnownext.py
e8aba6cf2ceb27074e677cc500ca9635 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/timerlist.py
5745efa3d167e1b32325aca015b54064 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/epgservicenext.py
d295b2e53f395a897bcc6adea5f7c979 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/zap.py
eb1350caa9f6ac76ff27f7c97f3a0e14 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/web/selectaudiotrack.py
469c272cc623e2dbe189e54abf22131e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/channels.py
5bee3f942ddd38910444f463855902f1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tvradio.py
25590e8a79db5ea82e42735753a94e3e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/satellites.py
3b62cf04cc71b2f4ff8b9f72397e4fd1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/eventdescription.py
24a69e25d9efb4fc7927fb5b5a609fec /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgdialog.py
28a6f6074df1ff5ad623832aa2b5bc63 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/screenshot.py
a6ac4be3efa1534712ccb36c2fc8b5b4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/edittimer.py
5e045532eeb1a55b0aaad4131f375f14 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/event.py
a333ab9b8c934879923977de1768729a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgr.py
7085530a95eb3dfff7484a8b1626770c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/providers.py
0f78ef9a7048eb3605618ae95fcb52cd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/message.py
08d738158287c3931655ee606ac00abf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/movies.py
7d77b72160f9e7ced772bc720e30f91e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/radio.py
fc55643ed97d793170993a30fdadd3d3 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/current.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/__init__.py
3771c9fdac995de296832f2808d0185c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/settings.py
2ca07cd50fbcfc843b6fdf9473f2b223 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/at.py
06af079b63f844b6ac1599e6c0c2287c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bouquets.py
19e33f2ed711264a7f08d12c8beda068 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/multiepg.py
db6f38fbb96d43af9fbbd7b94a53745d /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/tv.py
b02ba3c08d07a1179071f043554986e2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/webtv.py
a0756424decfff0e3cde65b5b5434ba6 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/about.py
d1efa3ac07b8b86037c2084a5bfc4459 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/epgpop.py
3b03f01e9b1797884b238ca1e9b615fa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/terminal.py
cb4ee879fa9f6bcf472751f1d3ef97c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/bqe.py
e2513044bc7d81f11e4d79f5c4c9a394 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/renderevtblock.py
1873a72adb77a3caef240ff02f873538 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/powerstate.py
86c48546fafdbfb9a022a71e3eb5a268 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/config.py
dd5d97f877e8aee10892a667bc978902 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/boxinfo.py
32343c4f1b35c3fe5e1194474ed343af /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/ajax/timers.py
11527dc431417b16f152c053f38b50c4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/index.py
7d940e6a1c21b12836519e7585c001e1 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/main.py
fb9d3ce662d477bd688725c750ae69de /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channels.py
45c809901af0ec05baacbc99d8a52cf8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/index.py
eac8f9de911bfb95b05f04169055b102 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/screenshot.py
00e3d3fb1987b98be0e5d702c3fab31e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/eventview.py
ab0e29e227d74a37b18750a4b6f8bf5c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/control.py
159c20c5a5ee4e3e24d7002783154cfd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/satfinder.py
46d265621d18bdd1f153fa5af3c2ccb5 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/movies.py
89af8e12285ef6bb1ce7763ad532ccf7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/head.py
d485eab30e93eca6a8e8930756843d6b /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/bouquets.py
a567b234cc170456d68e1874681b9fad /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/about.py
357d12450192ba4d7cd6ac9ad2b79de7 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/channelinfo.py
9a9e5dd7238fdecb24d04937840e5e41 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/mobile/timerlist.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/__init__.py
576b153178b5a094b45121ad51c283cf /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getservices.py
66bc55ecdc5944259bb3f630eef04c31 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/views/bouqueteditor/web/getprotectionsettings.py
3e5f87c1f0f8dbabe2eaf83b3a50d801 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ajax.py
a3fb255ba427fe9c3755efd41402f16c /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/ipkg.py
82e2b260ffbc8a896fbad6320cf60f05 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BouquetEditor.py
36082b395498b3a7d834f09ae477f9e2 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/api.py
8f0a388a14337b66349575a34ce95d50 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/mobile.py
c9cfd7dbb803939156debf601ac1b9aa /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/web.py
fa9f78ae4431068f2a614a9cf20c4b6a /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/base.py
3b818dbd521732b5e808113332f358cd /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/transcoding.py
778d9117c1a1f4577c086a362e2014a9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/wol.py
6d551c67d6022e42cb2dd428152f29f4 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/BQE.py
186b65680cbe8ccb070a3ddc67d961f8 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/controllers/root.py
784196d32b5284e434340978b980e2da /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/__init__.py
a968e836df31fea63bb4adcbf12906c9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/sslcertificate.py
d5ded6f5475689635166ff3e3decfce9 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/local.py
795e9ec1893edac2928206de2a547806 /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/__init__.py
0d1aedd2f897f09061ae6bfc78c4b61f /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/backport/OrderedDict.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhEpgBackup/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/External/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/__init__.py
f66e93ef0623fc4838c3757df3159ebb /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/WebChilds/Toplevel.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/__init__.py
b72c7859893a76cafdfc32c65e1df0fb /usr/lib/enigma2/python/Plugins/Extensions/PicturePlayer/plugin.py
2b567aa940f4431bc0ef9f781225287f /usr/lib/enigma2/python/Plugins/Extensions/OpenMultiboot/open-multiboot-branding-helper.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/MenuSort/__init__.py
12b4918d57dcb119adf4797dbc1abc52 /usr/lib/enigma2/python/Plugins/Extensions/MenuSort/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/__init__.py
8905ca88f7a8379ecb0118ecee9d46b2 /usr/lib/enigma2/python/Plugins/Extensions/BhFastEpg/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/__init__.py
24e81ac913b5983c0acf0b2e3c537d41 /usr/lib/enigma2/python/Plugins/Extensions/DLNAServer/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/DemoPlugins/__init__.py
31e52ae95724db4d598b8b6ea03e15db /usr/lib/enigma2/python/Plugins/Plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/__init__.py
fed4a705f0c1d9569302bb55d04c5d59 /usr/lib/enigma2/python/Plugins/SystemPlugins/CommonInterfaceAssignment/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/__init__.py
61f98a769c5ded0c8a64451697891120 /usr/lib/enigma2/python/Plugins/SystemPlugins/Satfinder/plugin.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/__init__.py
76d4fc9c9dc116285294f9b79adadbc0 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetDrive/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/__init__.py
34014a1e03557b2ea809a95f8ab2e1f6 /usr/lib/enigma2/python/Plugins/SystemPlugins/ZappingModeSelection/plugin.py
5cd63078da8d66aa7081d64b74692f40 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/SoftwareTools.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/__init__.py
b7c161d59170e825a894dec1d8b8c951 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/ImageWizard.py
da25b111fad50c4bd0e4ad9e244e3837 /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/plugin.py
d1e4f463eeb0272a2f86f40c3a77a7aa /usr/lib/enigma2/python/Plugins/SystemPlugins/SoftwareManager/BackupRestore.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/__init__.py
1440586470e4335ea4e9838d1c785379 /usr/lib/enigma2/python/Plugins/SystemPlugins/PositionerSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/BlackHoleApi/__init__.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/__init__.py
d8f9b54aeb4984c2c49cb649196d3b30 /usr/lib/enigma2/python/Plugins/SystemPlugins/Hotplug/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/__init__.py
3052bd0cb91c112794c630ac519bdf84 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/VideoEnhancement.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/__init__.py
f4516684cc11cc6e12bf3a38eb66b3c3 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoEnhancement/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/__init__.py
bb663a3aaf5263f588caac6c28b6844e /usr/lib/enigma2/python/Plugins/SystemPlugins/UIPositionSetup/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/__init__.py
027bd31cb0ddaaeb9cc6e967ae45403c /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/NetworkWizard.py
a2008372ff89c62d07cb31e6a9de091f /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkWizard/plugin.py
345624ddf9502612303aed3023d9e86d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountEdit.py
a9c118f12d3b3f4f0339c95f7778074e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/AutoMount.py
6a352b0bfe8173ec89e5ce895b01eb6d /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountView.py
286db9f715fa9c074016e0132750128e /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/NetworkBrowser.py
7010636521d6a0183f317e43ace396e2 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/__init__.py
340b79e10fdf7e759e103704b12fa2a9 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/MountManager.py
19b45c6ada80382a72629591ba86580a /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserDialog.py
da2d19e7d6c97c2f645bd34ce7fa7ff8 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/plugin.py
2fd13d35fa6df0843208e85cfcf3bef7 /usr/lib/enigma2/python/Plugins/SystemPlugins/NetworkBrowser/UserManager.py
b96ca0dcf09802b54a49653c799cafdd /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/__init__.py
ed5d1f3ba620894f6bf7ff9acc46dccf /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoShutDown/plugin.py
9f565e180deab436b5175874ee919ca6 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/VideoFinetune.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/__init__.py
6307b4f8a6952cfd3532bc8bed7cb817 /usr/lib/enigma2/python/Plugins/SystemPlugins/VideoTune/plugin.py
a3bd1b310b41e81ac6230ded8ac39d84 /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoHardware.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/__init__.py
caf98dfaaeb77e31a45cb860cba84fba /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/plugin.py
557df59d0d09a31064e9b2c68865b9fe /usr/lib/enigma2/python/Plugins/SystemPlugins/Videomode/VideoWizard.py
dad0227408777290e6c56afc03cf6e12 /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/__init__.py
0905898c9d2b681bde797d42cc60e63f /usr/lib/enigma2/python/Plugins/SystemPlugins/AudioEffect/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/__init__.py
867018726f190427b7a3e2060dd67396 /usr/lib/enigma2/python/Plugins/SystemPlugins/SkinSelector/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/__init__.py
b9711f9f6bbc5c63fe41cb89447b7adc /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoResolution/plugin.py
d784fa8b6d98d27699781bd9a7cf19f0 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/__init__.py
c5fb99fc59d1316b62db00118c180389 /usr/lib/enigma2/python/Plugins/SystemPlugins/WirelessLanSetup/plugin.py
ecaa88f7fa0bf610a5a26cf545dcd3aa /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/__init__.py
b753599eda3eb9e205b33fa3a52135c2 /usr/lib/enigma2/python/Plugins/SystemPlugins/HDMICEC/plugin.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Plugins/SystemPlugins/Fancontrol/__init__.py
e03d55bef212d176a9ce766c36f9ecf5 /usr/lib/enigma2/python/Plugins/SystemPlugins/Fancontrol/plugin.py
ab2eef0ec82f8afbd8e5f6ed5128f02c /usr/lib/enigma2/python/Components/Keyboard.py
a81c27e579fe62ddf5589246428dbdec /usr/lib/enigma2/python/Components/EpgList.py
4b27f5f16806fde8c7e6b0528082319f /usr/lib/enigma2/python/Components/Scanner.py
7be136b6d1eaa13aaa08832390bd53ca /usr/lib/enigma2/python/Components/Ipkg.py
fda2884a50d71cf31c89a54de97be5a2 /usr/lib/enigma2/python/Components/ResourceManager.py
ed446633b70188c44fcd2d4866044bbe /usr/lib/enigma2/python/Components/VideoWindow.py
cbc39aa5935ab3119f74e97329d4fef7 /usr/lib/enigma2/python/Components/SetupDevices.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/components.py
4b43daadcd4728b9b688c14c36062240 /usr/lib/enigma2/python/Components/Renderer/Picon.py
c947108f65672842ac96be1bf179690f /usr/lib/enigma2/python/Components/Renderer/Pixmap.py
f43a627a5e8fb9b7a4a5ca67db7bb42a /usr/lib/enigma2/python/Components/Renderer/Progress.py
7dcaf7bebd1b96408b3b13f90a61d512 /usr/lib/enigma2/python/Components/Renderer/PositionGauge.py
aa1249c9a1ce56691a227df891da902b /usr/lib/enigma2/python/Components/Renderer/FrontpanelLed.py
7779d00ec0633251a4b83020ef55551a /usr/lib/enigma2/python/Components/Renderer/Label.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Renderer/__init__.py
1d37518d1e9e86746b3167f8aaed0945 /usr/lib/enigma2/python/Components/Renderer/Renderer.py
6395adaf7ec9bd78244c6f24baf7489f /usr/lib/enigma2/python/Components/Renderer/Listbox.py
fdc2c0963d41b40e55dcbb2bc34caeaa /usr/lib/enigma2/python/Components/Renderer/ChannelNumber.py
83384daaed9da756f7866d192d26b4b2 /usr/lib/enigma2/python/Components/Renderer/Canvas.py
307cbe1c7396024115dbf83e5b77ef53 /usr/lib/enigma2/python/Components/Renderer/Pig.py
ae4183381040270c96baa391d91fb26b /usr/lib/enigma2/python/Components/Renderer/Bhclock.py
7b0aa9b18eb25016e3b5b3f250281731 /usr/lib/enigma2/python/Components/Renderer/FixedLabel.py
60149cfef7e38c49aae41ba703a4f034 /usr/lib/enigma2/python/Components/Harddisk.py
b1849862a81e9abe67116d8be9abaebf /usr/lib/enigma2/python/Components/AVSwitch.py
b0e458255e15f1a8aec85f6288ef085d /usr/lib/enigma2/python/Components/Button.py
1c4cac0789e596a771af1c7d358f2f84 /usr/lib/enigma2/python/Components/Console.py
4a5d006fa9b187e5008608b1b89bbff0 /usr/lib/enigma2/python/Components/ActionMap.py
c49b29929b4e4162394dc2f7a8c772f8 /usr/lib/enigma2/python/Components/ScrollLabel.py
464c8a0e511dc879697d1a0d9766ef3c /usr/lib/enigma2/python/Components/Pixmap.py
a0ee417c4b6315857b9a2eef5d2b1a0d /usr/lib/enigma2/python/Components/ServiceScan.py
6feeba1843947ec6baaeef017ad68230 /usr/lib/enigma2/python/Components/HTMLComponent.py
e2142332f63498ba1b11addbf4ed9446 /usr/lib/enigma2/python/Components/InputDevice.py
a839e937b494e57979f98a9c2d389c9e /usr/lib/enigma2/python/Components/TimerList.py
58fee00295729a2adb7033bf68371de7 /usr/lib/enigma2/python/Components/Converter/ProgressToText.py
da60ed1a4fde0806990486a01bd727e9 /usr/lib/enigma2/python/Components/Converter/ClockToText.py
450c953359065349aac382f76b21fdae /usr/lib/enigma2/python/Components/Converter/Poll.py
c34a0a1a3f90265b36cbf8336ea7b7c1 /usr/lib/enigma2/python/Components/Converter/ConditionalShowHide.py
a6ecc808c0328a437c61eb2ade05bea6 /usr/lib/enigma2/python/Components/Converter/ServiceTime.py
15bea5fc9dbe47aac657be4a34439961 /usr/lib/enigma2/python/Components/Converter/Streaming.py
4078e76e1346d8f2a5e874efd2b904ac /usr/lib/enigma2/python/Components/Converter/RdsInfo.py
38362c2c04914861eb86b7a7d69afa4b /usr/lib/enigma2/python/Components/Converter/ServiceName.py
28dde32d3346086a1ec64dc3ee1627f9 /usr/lib/enigma2/python/Components/Converter/FrontendInfo.py
e90e83fd0a8fc7b634792ecd2a6edbda /usr/lib/enigma2/python/Components/Converter/StaticMultiList.py
17956139931985e8f54cb633cc1af8e4 /usr/lib/enigma2/python/Components/Converter/EventTime.py
87e4bbae4ce58464d0c7ca9319726cd7 /usr/lib/enigma2/python/Components/Converter/MovieInfo.py
ac89bc29566c391499126b1a6f4500f6 /usr/lib/enigma2/python/Components/Converter/EventName.py
3176888cde9c0efeed9ae52282e73dec /usr/lib/enigma2/python/Components/Converter/TemplatedMultiContent.py
87c95b795e765d0651b875064d114541 /usr/lib/enigma2/python/Components/Converter/ServicePosition.py
58b6e06f16433368d76847d3aba80372 /usr/lib/enigma2/python/Components/Converter/ValueToPixmap.py
dc9a4c4fc79c6e128e0179fc30d19895 /usr/lib/enigma2/python/Components/Converter/StringListSelection.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Converter/__init__.py
2c2d157ea7d28a4a43f20b6408ac0394 /usr/lib/enigma2/python/Components/Converter/TunerInfo.py
2f5e9df85dd9c531dcf62a3aab5ecfe1 /usr/lib/enigma2/python/Components/Converter/Combine.py
5d971edffdd2cd735683bb4c9093ef35 /usr/lib/enigma2/python/Components/Converter/ConfigEntryTest.py
088bd12c66a5fe4c2b87678e274fc13a /usr/lib/enigma2/python/Components/Converter/MenuEntryCompare.py
a7de7fb276c23533cff437f8c978a4af /usr/lib/enigma2/python/Components/Converter/StringList.py
b13c107d6ad058ba60856abcb94cb0c2 /usr/lib/enigma2/python/Components/Converter/BhAnalogic.py
af3845fb48965e926fd51a7439c85ee6 /usr/lib/enigma2/python/Components/Converter/Converter.py
4b8d476929f2c17190baf9d38fa70afc /usr/lib/enigma2/python/Components/Converter/SensorToText.py
6028ba4c8f7d61199ff5b7930089058f /usr/lib/enigma2/python/Components/Converter/HbbtvApplicationInfo.py
73a07616a11fe77a022194d58b0940e7 /usr/lib/enigma2/python/Components/Converter/ValueRange.py
4c78fa5f5bf79d7fffe80a9a568043c0 /usr/lib/enigma2/python/Components/Converter/RemainingToText.py
919b568ec0ddeddd7798d2641e444c9e /usr/lib/enigma2/python/Components/Converter/StaticText.py
42b16b575d76c0e130ff3f007497d354 /usr/lib/enigma2/python/Components/Converter/ValueBitTest.py
12ce3af4bd6cd4a42268832d6863333a /usr/lib/enigma2/python/Components/Converter/ServiceInfo.py
740cfba1ec935bde6fcf238d13cf103c /usr/lib/enigma2/python/Components/TimerSanityCheck.py
8bcf68f46c11af120dcfc5e51ee0e720 /usr/lib/enigma2/python/Components/Playlist.py
630323f4905e84479b1ba21efdc799bd /usr/lib/enigma2/python/Components/PluginComponent.py
6d4f8f7e30285110a59c0e30c62640fd /usr/lib/enigma2/python/Components/PerServiceDisplay.py
c498dfaa263d90bd6f75430b02ab7ee4 /usr/lib/enigma2/python/Components/MenuList.py
0660039b7b6e30b0f2274b222ead3741 /usr/lib/enigma2/python/Components/ConditionalWidget.py
9f0161d7c0504b6ef817767d2bed97d5 /usr/lib/enigma2/python/Components/Label.py
8a0fe43501d2ad168ea15b4b4f147b84 /usr/lib/enigma2/python/Components/ServicePosition.py
ab40fec58293a5ab3975c557d4cc869c /usr/lib/enigma2/python/Components/Network.py
1bd1c3e110097a9e5e15b7a7ccd225ee /usr/lib/enigma2/python/Components/GUIComponent.py
dda068dfd8bafba0f653154a9f7cdc20 /usr/lib/enigma2/python/Components/PluginList.py
b0869deccb48eb53982607aef33c3978 /usr/lib/enigma2/python/Components/Gauge.py
0e01a1e3e304e69f8d1b89a8ef22cd31 /usr/lib/enigma2/python/Components/About.py
fa8b4d5880fe760f60a934b4b68c9046 /usr/lib/enigma2/python/Components/SystemInfo.py
5d8bb240d49bab580713e5e4168be5d6 /usr/lib/enigma2/python/Components/ServiceList.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/__init__.py
24d7a0e6c32db9731a60dd1b5b66ca76 /usr/lib/enigma2/python/Components/TunerInfo.py
2df5c6036279e5320b28f8c46dac0c5f /usr/lib/enigma2/python/Components/FileList.py
a3e6763f5cbccdd67a60f64a2d67e32e /usr/lib/enigma2/python/Components/ConfigList.py
ee73da21a06410074bb749968c680955 /usr/lib/enigma2/python/Components/TuneTest.py
5f0b35419c901af9d211dc93b84e55d0 /usr/lib/enigma2/python/Components/HdmiCec.py
4fdc9ae13b1284850d6f4153d44213cf /usr/lib/enigma2/python/Components/ProgressBar.py
3b5dc0f7bf90523b8401499ae1c7aaec /usr/lib/enigma2/python/Components/VariableText.py
4bb6712fcb467e24fbe9f4aec3ca4f0a /usr/lib/enigma2/python/Components/FIFOList.py
a08636829f357ad582d52b123921b7ac /usr/lib/enigma2/python/Components/Lcd.py
293601b503ad89e0ebe9bc8ef85c9dd8 /usr/lib/enigma2/python/Components/MultiContent.py
30bcad129a42eefaf90afed0e920a1ce /usr/lib/enigma2/python/Components/RecordingConfig.py
eaed1748abf9a6eda5113f38bc77031f /usr/lib/enigma2/python/Components/GUISkin.py
4bb39ca2744867c41ff9d4230599e144 /usr/lib/enigma2/python/Components/Input.py
0d707152124791c90b82fbc6e844918d /usr/lib/enigma2/python/Components/HTMLSkin.py
6b7b951377d6db820960505ffc699f2b /usr/lib/enigma2/python/Components/HelpMenuList.py
11000ec9591b9e5a9f5bed4037d2c91f /usr/lib/enigma2/python/Components/VolumeBar.py
856bd947a95eec1fc67ff9ea080eda6f /usr/lib/enigma2/python/Components/Netlink.py
fdd79c3bfa2aae2a5d0b6fe8951ce439 /usr/lib/enigma2/python/Components/Sensors.py
c9da57a45f2d4465e16b51dd994bc79e /usr/lib/enigma2/python/Components/DiskInfo.py
2e5c620136817ebddfa7b3331244113b /usr/lib/enigma2/python/Components/Task.py
37b4c0973bfa775b24acf163ee6ddf90 /usr/lib/enigma2/python/Components/InputHotplug.py
f8f228a176cd0b7a13ef5523f00e8ec1 /usr/lib/enigma2/python/Components/UsageConfig.py
a0185f66b4b197a347e9b10038323958 /usr/lib/enigma2/python/Components/ParentalControl.py
7d06bd081dd0e10b7019d8ac58708949 /usr/lib/enigma2/python/Components/Element.py
7e49d10afc58c996a3612dffa12304aa /usr/lib/enigma2/python/Components/MediaPlayer.py
bc97eb5963b13419cfe4f1d9dc4a7c6f /usr/lib/enigma2/python/Components/DreamInfoHandler.py
455a470bf796884de3cf5886fbbdbdb8 /usr/lib/enigma2/python/Components/FanControl.py
c6ad0278e7f0a4acba4de4b6804fe715 /usr/lib/enigma2/python/Components/SelectionList.py
6b97ff9a5291eb296cfcefc28ceaceef /usr/lib/enigma2/python/Components/VariableValue.py
840db4ecd1bd402488af8bc0ff9a47e1 /usr/lib/enigma2/python/Components/ChoiceList.py
b57e4b58fa040ccf621c0fd4693bb3bb /usr/lib/enigma2/python/Components/MovieList.py
41e413d2ffa48a03fd0547df3b9a948b /usr/lib/enigma2/python/Components/config.py
f2edeec29b502db62369e2283816ead4 /usr/lib/enigma2/python/Components/Sources/Event.py
7c307f1c09f73fbd61de82c2e2544d3d /usr/lib/enigma2/python/Components/Sources/EventInfo.py
b2b638612aa61f66e5c729d969dc96b6 /usr/lib/enigma2/python/Components/Sources/RdsDecoder.py
47312dcaaea9e981b3e22b2363898485 /usr/lib/enigma2/python/Components/Sources/FrontendInfo.py
11bd6ef9d574ab79c97d9f5160cabece /usr/lib/enigma2/python/Components/Sources/CanvasSource.py
c2929a5e2de2d1b3a94e2c38cd7274c5 /usr/lib/enigma2/python/Components/Sources/Progress.py
78c43ab613a6166cf5858eb963ba62bd /usr/lib/enigma2/python/Components/Sources/Config.py
1da1958b336de06b874c9facb97d8e3e /usr/lib/enigma2/python/Components/Sources/ServiceEvent.py
5723d19be11ccbffd48502ade1010767 /usr/lib/enigma2/python/Components/Sources/List.py
6a85468d2ac38a7f37dbc5f73415ca8f /usr/lib/enigma2/python/Components/Sources/ServiceList.py
647e2f65fb79b2fae4a1c2ce5007b656 /usr/lib/enigma2/python/Components/Sources/CurrentService.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Components/Sources/__init__.py
f68dc995f78cfc88e26483ea787746ab /usr/lib/enigma2/python/Components/Sources/TunerInfo.py
8962f4fa89d8ff7fb8097e84ea120158 /usr/lib/enigma2/python/Components/Sources/HbbtvApplication.py
c6f7285e3f449c301dab92d92cfb1fce /usr/lib/enigma2/python/Components/Sources/FrontendStatus.py
ab296b833f2d34f06b5ac2a16c782df3 /usr/lib/enigma2/python/Components/Sources/Source.py
ce001a44e6f7098624a6df98c1c5761b /usr/lib/enigma2/python/Components/Sources/Boolean.py
3059a135ceb0c3fca0867698f21fc2b7 /usr/lib/enigma2/python/Components/Sources/StreamService.py
d421be00754d02d85df804e4faea908f /usr/lib/enigma2/python/Components/Sources/RecordState.py
b8b12180202bc1ca61007fd6b7ec7009 /usr/lib/enigma2/python/Components/Sources/StaticText.py
44460c27e2763fb358898dc34907c140 /usr/lib/enigma2/python/Components/Sources/Clock.py
56c35c1b2af81757e84913b3eb816e6e /usr/lib/enigma2/python/Components/Sources/Sensor.py
db075a06a00091ac91dfdaae6fc66e37 /usr/lib/enigma2/python/Components/language_cache.py
3966e9a92370bdfcf0175147a6ca5422 /usr/lib/enigma2/python/Components/ParentalControlList.py
5ca34b71f3b1f9f09d32a4a150498935 /usr/lib/enigma2/python/Components/Timezones.py
2d91cb867af3a14de7b63d70ca2af744 /usr/lib/enigma2/python/Components/NimManager.py
62c655bbacc907e84cd14c4dc9972546 /usr/lib/enigma2/python/Components/BlinkingPixmap.py
ae9baee8c742036b23345f88e775a15f /usr/lib/enigma2/python/Components/Slider.py
b2fe45714c4a542dc0aea365aabd3bb1 /usr/lib/enigma2/python/Components/ServiceEventTracker.py
eff3a2b1612845f6e9193f4a89796a7a /usr/lib/enigma2/python/Components/VolumeControl.py
8a566189add219ba26e3204f2eb21164 /usr/lib/enigma2/python/Components/Language.py
2c1bd3117309881fef653c59d6d3b858 /usr/lib/enigma2/python/Components/RFmod.py
90395cfd60fa25b5d60090655ed32b87 /usr/lib/enigma2/python/enigma.py
cfac1258e71864b1ce1e0874fd70d854 /usr/lib/enigma2/python/Screens/LocationBox.py
b5bc1d71a6b661898d46e07c8152d592 /usr/lib/enigma2/python/Screens/Ipkg.py
6b68c3e2070a4cadf05548549a43c785 /usr/lib/enigma2/python/Screens/Globals.py
586378f913a22adf52d797d07007e082 /usr/lib/enigma2/python/Screens/MovieSelection.py
6ca7aaac688af8fd97714fed42b0c771 /usr/lib/enigma2/python/Screens/ChoiceBox.py
5cde673819bd05fab243d2f7cff90f72 /usr/lib/enigma2/python/Screens/VirtualKeyBoard.py
524fa9ce443eae4668e581cb996f7364 /usr/lib/enigma2/python/Screens/Console.py
5e0802b1298864f2d490a0448d8a2ff2 /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
ca0361953b30f5fc919c4b77abfca0fb /usr/lib/enigma2/python/Screens/TextBox.py
7b7a1f9add7e65ef4df0d89fa3162492 /usr/lib/enigma2/python/Screens/ServiceScan.py
5c836403cce8a029cdec5afa8538eb3c /usr/lib/enigma2/python/Screens/PiPSetup.py
4c7cdc559cb51a0281d41d4a3da63592 /usr/lib/enigma2/python/Screens/StartWizard.py
df19a69823ea0743d51f8492e5719da2 /usr/lib/enigma2/python/Screens/AudioSelection.py
262b973b6346f1669ad83e2c67400a09 /usr/lib/enigma2/python/Screens/PVRState.py
3c44a1bb0a6687a3e8c4decd65b9fa43 /usr/lib/enigma2/python/Screens/MinuteInput.py
21b0cca3002cf88fa8868bce113ab96c /usr/lib/enigma2/python/Screens/SessionGlobals.py
e7bc2feca9f12a9169bc74c79d034e65 /usr/lib/enigma2/python/Screens/TimerSelection.py
616e4f5f8d67699c3564ac495ea4e091 /usr/lib/enigma2/python/Screens/ClockDisplay.py
3d02e244781570049d5813d9f5178542 /usr/lib/enigma2/python/Screens/Ci.py
55e33dc3c555fe34560e8c05677eecb6 /usr/lib/enigma2/python/Screens/PluginBrowser.py
2fbb9c8d85a3144ac01a5d09e5219a6e /usr/lib/enigma2/python/Screens/TutorialWizard.py
fafa8e1cdfb5c7994ec52f7a627e58bd /usr/lib/enigma2/python/Screens/HelpMenu.py
1d812b4508da64c54eaf3aafe30eb1c5 /usr/lib/enigma2/python/Screens/Rc.py
b0b2b95a755c5d9d15975fe028821f3e /usr/lib/enigma2/python/Screens/EventView.py
2348eb5cf08ee69a16de2f1815d3618b /usr/lib/enigma2/python/Screens/About.py
d41d8cd98f00b204e9800998ecf8427e /usr/lib/enigma2/python/Screens/__init__.py
74dcf98e11a972d249ce5fd011b97cb8 /usr/lib/enigma2/python/Screens/SimpleSummary.py
15b19e6f30826c97c7fdfe0b35ad71c2 /usr/lib/enigma2/python/Screens/UnhandledKey.py
db4555335ae0e5fe01cc917721aa7ae7 /usr/lib/enigma2/python/Screens/Standby.py
d189f053b000b612c630638cca19912c /usr/lib/enigma2/python/Screens/LanguageSelection.py
d501bc67ff36572c521ab3bd01da6cca /usr/lib/enigma2/python/Screens/WizardLanguage.py
9fd6f2768180b538d3f35ce3e8cebcab /usr/lib/enigma2/python/Screens/SubtitleDisplay.py
e5a84350b94e7e7c27dc57fcd00dff1c /usr/lib/enigma2/python/Screens/TimerEntry.py
3fe046757ebdbe062517190b33c226d1 /usr/lib/enigma2/python/Screens/ChannelSelection.py
2026309d4bb26a778822e85541918335 /usr/lib/enigma2/python/Screens/Volume.py
372ed995725f003f56e3f231e0b3636c /usr/lib/enigma2/python/Screens/HarddiskSetup.py
c5c0ac1908fd39967894d1044d32520f /usr/lib/enigma2/python/Screens/RecordPaths.py
796833f63a98ce6cb2284242c8a23689 /usr/lib/enigma2/python/Screens/Subtitles.py
2c371a88055a052e82401b97646771e5 /usr/lib/enigma2/python/Screens/Mute.py
5c715725c78fb2a0f4133663291994c9 /usr/lib/enigma2/python/Screens/Wizard.py
910794de58e03cb7a9e68b5b15900fd5 /usr/lib/enigma2/python/Screens/InputBox.py
bccc795a82aab24bd114c264706fedeb /usr/lib/enigma2/python/Screens/TaskView.py
494d95e3c66df7ead1bf1adb38f7d2b1 /usr/lib/enigma2/python/Screens/Scart.py
f09c91475b4d47bac3112605a1d520e1 /usr/lib/enigma2/python/Screens/InputDeviceSetup.py
feb6b7a31bb9716fd322cec27a4166cb /usr/lib/enigma2/python/Screens/MessageBox.py
24faf928d0834df700ae9058b66670d3 /usr/lib/enigma2/python/Screens/PictureInPicture.py
a470453fae4245fc4905c768066384ae /usr/lib/enigma2/python/Screens/Screen.py
211f268cfa597d7eb6b1f17891224bcd /usr/lib/enigma2/python/Screens/SubservicesQuickzap.py
1caf3058700bdc87bc00c54f2a85eceb /usr/lib/enigma2/python/Screens/NumericalTextInputHelpDialog.py
664d96d2d6a5b14e70a8c226f1e50dc3 /usr/lib/enigma2/python/Screens/Menu.py
a1887da61746d8c7b190c1f9a6f79a5e /usr/lib/enigma2/python/Screens/Dish.py
f49c2918da9b1870bac153faa8717f91 /usr/lib/enigma2/python/Screens/TimeDateInput.py
a6c418ca660943e42fa2b2c72b8c2f7e /usr/lib/enigma2/python/Screens/FactoryReset.py
ea3df01e230dfb0e76fe1f6b8755b247 /usr/lib/enigma2/python/Screens/TimerEdit.py
d8ab85121817e311e336d530942f4e0c /usr/lib/enigma2/python/Screens/FixedMenu.py
30ace57c455e7f9755a5d1738671ba62 /usr/lib/enigma2/python/Screens/ConfigMenu.py
d0f876e8eb9172806e98e8bb849aadb2 /usr/lib/enigma2/python/Screens/SleepTimerEdit.py
4b4246ba0ca9bf6b3f9ea8cf788dc7aa /usr/lib/enigma2/python/Screens/ServiceStopScreen.py
6b6dfa299891f60e4e5365c6c04d31b7 /usr/lib/enigma2/python/Screens/Setup.py
5c995a40de39886c79d9fe3c3d45d7f7 /usr/lib/enigma2/python/Screens/RdsDisplay.py
1861fd026825e52275d5bc8130a85479 /usr/lib/enigma2/python/Screens/ScanSetup.py
2690da67e19ff3dc9c5bf2e9674c3353 /usr/lib/enigma2/python/Screens/ParentalControlSetup.py
8fa9bc346413ef0bfbfd28a48bd2a646 /usr/lib/enigma2/python/Screens/Satconfig.py
c1f4bd69a0bb36ac327f3c4603b685d0 /usr/lib/enigma2/python/Screens/ServiceInfo.py
b99d40f2285c4bf88f90e46d066769c2 /usr/lib/enigma2/python/Screens/InfoBar.py
202a551180e1dfdcf4e7ae135d8de685 /usr/lib/enigma2/python/Screens/EpgSelection.py
e5ddbe48ebcb52a8cd018a0ee96a4217 /usr/lib/enigma2/python/Screens/QuadPiP.py
32afe8c8ca5e3bb865af86a296951d12 /usr/lib/enigma2/python/Screens/DefaultWizard.py
9da9efb4c10abe7075196033f4c3a6e5 /usr/lib/enigma2/python/Screens/NetworkSetup.py
10051dbd540c9f7e66fa8f7d88954d84 /usr/lib/enigma2/python/skin.py
0b4897696936a4c0799525c7f1e73166 /usr/lib/enigma2/python/timer.py
82af22ea3c6d5b0c13e57e244b497d1f /usr/lib/enigma2/python/ServiceReference.py
b72cf1b58e9719a8fc9955730fcf601c /usr/lib/enigma2/python/mytest.py
c8cb7ffe121f512968813014bcabf0cd /usr/lib/enigma2/python/e2reactor.py
833f487b66ded4f59a4f567fc26f8072 /usr/lib/enigma2/python/RecordTimer.py
bda1854fa7c66bbf581db1ec7d60b04c /usr/lib/enigma2/python/Tools/Transponder.py
dbbb881f6c856e4cab017f518ba4a68a /usr/lib/enigma2/python/Tools/CList.py
8c8b3e4062f8e5e9c72cceac90320a2f /usr/lib/enigma2/python/Tools/Profile.py
fec44e3c680135b636adcbc71044cab4 /usr/lib/enigma2/python/Tools/Event.py
2bb2eab34660b5fcdf0b30f9bd1e8f44 /usr/lib/enigma2/python/Tools/Notifications.py
a0639de72e3006e1001f4bf549017bb9 /usr/lib/enigma2/python/Tools/Directories.py
fc8e1e93a7429fba50acb0261f7f5268 /usr/lib/enigma2/python/Tools/RedirectOutput.py
5e58ee8495c6b18b588e7c5b6069fa4c /usr/lib/enigma2/python/Tools/Downloader.py
cbe6d03d0dd9d165c8ec776c5c9adcce /usr/lib/enigma2/python/Tools/ASCIItranslit.py
a2218e726395499f00c72c393da3ba2c /usr/lib/enigma2/python/Tools/LoadPixmap.py
e3356c99fc63880d7cbe4495a03adb68 /usr/lib/enigma2/python/Tools/__init__.py
d9d83467815003e745113b9a16a1473d /usr/lib/enigma2/python/Tools/DreamboxHardware.py
b3422d679770a129342e52f6ca2978ad /usr/lib/enigma2/python/Tools/NumericalTextInput.py
df159721c742ec280d6a9a585700f88b /usr/lib/enigma2/python/Tools/HardwareInfo.py
0f292c2f68d9da26d688abc4f4f3a10d /usr/lib/enigma2/python/Tools/Alternatives.py
b4011bd490319162c0bb7ab1fe0816f9 /usr/lib/enigma2/python/Tools/BoundFunction.py
c542bb10e8db238b1bd7cf3e2ca06aa9 /usr/lib/enigma2/python/Tools/XMLTools.py
8d778f7f354f41c9d59672cfc25c4364 /usr/lib/enigma2/python/Tools/KeyBindings.py
b59a24f3c4925c36ab2b5c20a47d70cd /usr/lib/enigma2/python/Tools/ISO639.py
09af65390e201fdc839573e5a5bc43f6 /usr/lib/enigma2/python/Tools/FuzzyDate.py
d364549956b3cfabe13d9b6b561232df /usr/lib/enigma2/python/Tools/Import.py
9a63922ca8a033d539a61fdb0baffb68 /usr/lib/enigma2/python/Navigation.py
46cf5439c0702ae3d52adf1e0df028af /usr/lib/enigma2/python/NavigationInstance.py
2847ae9cd6ce7ef306501d30d1b675d3 /usr/lib/enigma2/python/SleepTimer.py
9ff38d1fbf23999885065144d273019f /usr/lib/enigma2/python/keyids.py
41d347a6305f5523347e1d4e7b5e9989 /usr/lib/enigma2/python/GlobalActions.py
7b1eaef5e94cdd6bd40f3bc0f7f1d794 /usr/lib/enigma2/python/keymapparser.py
943167eb90dc3145e1b9f61dbd098c3b /usr/lib/enigma2/python/tools.py
</pythonMD5sum>
</crashlogs>
</opendreambox>
Pls test all this with tuner and with image in flash ,not Multiboot and not Universe.
If you have only image crash in Multiboot and in the universe I can not help then is not skin BUG.
New Skins BH 3.0.5
eight new skins for BH 3.0.5 full coding
Download Black Hole Image server
(Green button >>> Yellow >>>Addons Download Manager>> Black Hole Image skins)
Skins support some important plugins
such as IPTV Player, File Browser and EMC Media Center
All skins format 1920 x 1080
all skins using picon format 220 x 132
Eclipse skins using PIG (small TV) in most panels.
Eclipse FHD (for BH 3.0.4.A and up ver)
Eclipse Fire (for BH 3.0.4.A and up ver)
Eclipse SE (for BH 3.0.4.A and up ver)
MX Maestra SE1 (for BH 3.0.4.A and up ver)
MX Maestra SE2 (for BH 3.0.4.A and up ver)
MX Maestra SE3 (for BH 3.0.4.A and up ver)
Waves 1 (for BH 3.0.4.A and up ver)
Waves 2 (for BH 3.0.4.A and up ver)
Eclipse FHD
Eclipse Fire
Eclipse SE
MX Maestra SE1
MX Maestra SE2
MX Maestra SE3
Waves 1
Waves 2
Nice Prince MX,
I like Wave 1 and Wave 2...new concept.
:idea::thanks:
Oh, it's funny how people want to make things complicated with this old feature Universe... What for? Or did you mean the much more useful Open Multiboot?
Let us know what you meant, exactly. Lately, I haven't had real issues with images installed in Multiboot: so I suspect it's really the old universe the source of your problems, isn't it?
Hello MX,
I absolutely do not claim that the error lies on the skin side!
I described the problem in this thread because the GSs did occur after loading the new Eclipse FHD skin, but I think that these BSs are probably the result of some conflict between the new skin and some elements of the previously installed software.
I only had 4 GSs in the first hours of using the Eclipse FHD skin, and although I have been using this skin for several days, so far more of them have not appeared.
I am forced to use UNIVERSE and Multiboot due to the small amount of flash memory in my Duo.
Best wishes for a New Year
Question @Matrix10
Is it not possible to make an 3840 × 2160 resolution skin on the new 4k receivers (ultimo 4k and more).
Also if this is possible,then the integrated youtube application would show full UHD, since it is the upscaled skin (1080p )that holds back full uhd passthrough, from other apps like youtube.
It is not possible.
In principle, I do not see the reason for the increase in resolution, which would again have a negative effect
to the image performance.
Namely, the quality of the graphics and letters is quite good and the further increase in the resolution would have more negative than a positive effect .
About Youtube.
I did not understand.
Skin does not affect the resolution of youtube or any videomovie from other addons/plugins .
Again I mean youtube video not youtube graphics/skin.
Skin does not affect the resolution of movies and videos.
Actually indeed the skins affects the plugins(some plugins)
The building Youtubetv which is part of the chromium OS in the vu + 4k uses the adresss http://www.youtube.com/tv , however the app takes your current skin resolution and set a max resolution for playing videos.
Also why in the Youtubetv( more info , and statistics for nerd) you would see that it does exactly that, setting max 1080p
you can do a simple test , by going to your browser on your windows pc and then turn up scaling up down and you would get same results,or make a simple webkit app with like PyQt wich also uses chromium browser and unless that app is using fullscreen , and none scaling, that app would also be affected same way.
You can say that skin resolution for both chromium browser and apps used by that browser on the 4k models , do not uses it full potential. And that is why i am interested in if it is possible to make a full 2160p skin.
I would not discuss it further. For now, it is not possible to have a skin in 4K resolution
However, your viewing plugins work is not correct
Skin has nothing to do with movie resolution,, which you can get using a plugin.
By that theory if I put old skin 1080 x 720
I can not watch UHD TV anymore and all movies would be in that format.
It's all about how it's coded in plugin, image and drivers and not in the skin.
Skin resolution can only affect the resolution of the skin (plugin)
if it is not coded for the same resolution.
But it can not have the effect on the resolution of a movie or some other video.
If we had 4K skins now
all plugins would be with small panels because they were coded for 1080 x 720 or for 1920 x 1080.
If they give video in SD format it will not become 4K because the skin is 4K.
If you think that skin is the one that determines the resolution of YouTube
then make a config panel where you can choose which YouTube resolution you like to have independent of the skin resolution.
No you misunderstood , i said that plugins that uses Chromium browser is affected by the skin, also why the youtubetv app is affected, since it runs via chromium browser
standalone plugins that dont use the browser for display wouldn't be affected.
I fiddled already played with the cromium browser code, however it can only run at what ever the skin is.
and back to my question was only if it is possible to do a 4k skin , or does the vu kernel not allow it ?
Well, I've already answered those questions.
That's more a question about image and driver coding than about the skin itself.
I do not know the answer because I do not code image and drivers, but only skins.
I really don't see the point in having a 4K skin: it would be a nonsense.
The skin's task is to display menus, infobars, lists and so on. The resolution is for videos and pictures.
For instance, if you talk about computers and you are a photographer, then the resolution of your monitor is important to get every details. But the GUI elements will be the same than at lower resolutions. Indeed, they will be smaller and this will make your experience with the O.S. worse, because every icons, every menus and its items, would be smaller and with smaller fonts. And you'll probably choose bigger fonts for the GUI non to became blind.
With bigger fonts and bigger icons, it'll seem that the GUI is the same but you'll still can work with pictures and videos with much more details.
Well if the skin drags down the rest of the entire chromeos i cannot see if it is nonsense, basiclly now its a 4k UHD satbox without the fetures of 4k and is left as a 1080p box.
So, learn how to design a skin and creates them for your own: Matrix and the other skins' designers are not your employees.
For everyone here except you they do a fantastic job (for free, even) and we feel really grateful to them, especially to Matrix whose skins are one of the distinctive elements of our BH and OBH images.
Or ask VU+ to put their designers at work.
I have a better idea to erase all HD and SD channels
and leave only 4K
I'm afraid we would not have much to see ,at least not for the next few years.
:chair:
What are the advantages and disadvantages of such a 4K skin ?
Does that make some great improvement or not ?
Does this have a major negative effect on image and performance ?
That's the main question.
Even if we had support within the images.
My opinion
the quality of so called FHD skins 1920 x 1080 is more than satisfying in relation
on TV video material including 4K.
4K skins That means everything has to be changed
from image to addons and skins,
and the impact of the size of the graphics on the same.
Taking into account in quite a big impact on the overall performance.
Of course, I respect other opinions as well
especially if they come from those who know this matter....
