New Vu+ Zero
Hi,
I just replaced a DM500s with a new vu zero. The problem I have is that the dish (with motor) is not tuning to channels. I created the usual setup with longitude and latitude but it doesnt seem to control the dish properly. I tested the same box on another motorised dish and worked perfectly (without changing any settings).
Does anyone know what I need to check please?
http://www.vuplus-community.net/board/threads/howto-usals-motorized-dish-and-scr-unicable-lnb.13352/
Hi,
My setup has only 1 motorised dish, shouldn't it work with the normal setup > simple > positioner > long and lat ?
sorry for asking.. but what do you mean exactly by "load a motor setting" ?
download a motor setting (vhannibal or whatever you prefer) and with enigmedit you send the channel list to the vu zero, then set the tuner as motor, simple and try again
How is the zero reciever in the coprative with vu solo?and tell the diffirences please?and which one is the best one in program,...?and which one is better to buy?
