No channels found
DN_Sami
BH Lover
Hello, i have downloaded BH 1.6.5
When i scan for channels it says 0 channels found.
But when i go to Satfinder and look for signal, i do found signal and its locked.
I did upgrade FPGA but still same problem, what to do?
Same problem on both of my UNO.
Please help!
Hello, i have downloaded BH 1.6.7 beta 3
i dont know how to do update drivers.
Please help!
Please help!
Are you sure that the lock is on the right satellite ?
You may have the lock on the wrong satellite / transponder.
First of all, check the antenna installation
because with the old drivers you would find hundreds of channels.
And you have zero channels
what is not normal.
Hi, I have the some problem. I receipt the decoder yesterday and all was working all right with the original firmware. After I have updated with BlackHole 1.7.0 and when I set the tuner to astra then I scan for channels it says 0 channels found.
If I change to other decoder this other receive the channels good. I only have Astra by community atenna so is impossible set another sattelite.
Can you help me?
Regards,
Javier
Can you help me?
Regards,
Javier
Check your tuner setup.
How did you set it?
@ javierrc
Probably your UNO had an old official image, then you have to upgrade FPGA first, and then install Black Hole image.
Bonjour j ai le meme probleme avec blakhol 1.70 et vti 4.0 et vx 2.3 pas de chaines trouvees meme avec la presence du signal
j ai esseye tous les astuces sans succes et je sui revenu sur l ancienne versio 1.66
