Request No service found with AVerTV Volar HD DVBT Tuner
CONOR
I have the 1.71 image on a VU DUO new box and have connected the AVerTV Volar DVBT tuner to the USB. When I perform an auto scan I get no service found.
One of my stations I'm looking for is at 737.978 Mhz a DTT channel.
I'm In Dublin, Rep of Ireland.
I have tried a manual scan but get the same results.
I cant see any info on the manual scan settings.
The Tuner is recognised in the list of tuners.
Any help available on same issue.
Mito
Check your tuner configuration setup.
The Terrestrial provider setup has to be: Europe, Middle East, Africa: DVB-T Frequencies
CONOR
Thanks for the reply.
The Terrestrial provider is setup to: Europe, Middle East, Africa: DVB-T Frequencies
I was looking to try the manual scan but dont know how to adjust the different settings
Does anyone know.
Has anyone actually tuned one of the AVerTV Volar DVBT with BH image 1.7.1 as the tuner is ticked as working under the USB Tuner section.
I have a roof arial set up and have tuned a sony tv and a philips tv to both digital & analogue channels but dont use the analogue as the digital is superior.
The channels Im trying to tune are the Irish saorview channels RTE1, RTE2, TV3, see http://www.saorview.ie/
CONOR
Hey Conor,
I had the Volar HD stick and I couldn't get any service either. I bought another Volar, A867 and that's working better, although after 48 hours it craps out, see my post http://www.vuplus-community.net/board/threads/black-hole-vu-duo-1-7-1-server-tuner.4898/page-3.
Apparently things are better in 1.7.2 and I will try later tonight.
Welcome to the DVB-T nightmare...
Palinkat
Thanks for your reply
I tried to see if the tuner worked with the avermedia software supplied and it didnt so I assumed I would not be able to tune it to the Irish freeview terrestial service (it uses mpeg4 as opposed to mpeg2). I then uninstalled the avermedia software and set it up with windows 7 and the windows 7 media player and it works perfectly which shows that Its capable of tuning to the local terrestial channels and I just need the right software on my vu duo.
angelofsky1980
BlackHole Driver Specialist
Palinkat
I've tried with my Uno and BH 1.7.2 out-of-the-box
Devices connected in USB:
A. Back:
1. multicard reader (XD+CF)
2. wifi dongle N-300 (VuPlus)
B. Front:
1. Aver Volar Black HD A850 DVB-T
All works correctly (286 services found) and vision is OK.
Output of the box (dmesg command):
dvb-usb: found a 'AverMedia AVerTV Volar Black HD (A850)' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9015.fw'
dvb-usb: found a 'AverMedia AVerTV Volar Black HD (A850)' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
DVB: registering new adapter (AverMedia AVerTV Volar Black HD (A850))
af9013: firmware version 5.1.0.0
DVB: registering adapter 1 frontend 0 (Afatech AF9013)...
MXL5005S: Attached at address 0xc6
dvb-usb: AverMedia AVerTV Volar Black HD (A850) successfully initialized and connected.
usbcore: registered new interface driver dvb_usb_af9015
Content of the file /proc/bus/usb/devices:
root@vuuno:~# cat /proc/bus/usb/devices
T:  Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12   MxCh= 2
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0001 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ohci_hcd
S:  Product=Broadcom STB OHCI
S:  SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=   2 Ivl=255ms
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12   MxCh= 2
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ehci_hcd
S:  Product=Broadcom STB EHCI
S:  SerialNumber=ehci_hcd
E:  Ad=81(I) Atr=03(Int.) MxPS=   4 Ivl=256ms
T:  Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=07ca ProdID=850a Rev= 1.01
S:  Manufacturer=AVerMedia
S:  Product=A850 DVBT
S:  SerialNumber=302795101891000
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_af9015
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 2
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 0
P:  Vendor=0dda ProdID=2026 Rev= 1.9c
S:  Manufacturer=Generic
S:  Product=USB2.0 Card Reader
S:  SerialNumber=0000001
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E:  Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T:  Bus=01 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  3 Spd=480  MxCh= 0
P:  Vendor=0bda ProdID=8178 Rev= 2.00
S:  Manufacturer=Realtek
S:  Product=802.11n WLAN Adapter
S:  SerialNumber=00e04c000001
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8192cu
E:  Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=84(I) Atr=03(Int.) MxPS=  64 Ivl=125us
Matrix10
I do not know the various performances of the DVB-T because I do not use.
But I can confirm AVerTV Volar DVBT tuner working in West EU .
I think this is a specific problem for Rep of Ireland.
Palinkat
Thanks All for your reply,
It's indeed a specific problem for the rep of Ireland. There has been reports of people leaving the scan ON even though it says 0 service found and it eventually finds them but I haven't tried (I sold my A850 stick).
I would recommand getting an WinTV Nova or Aver A867 and of course a Powered USB hub!
Cheers
angelofsky1980
Cheers
Try to verify also the content of terrestrial.xml datas about your country :)
CONOR
vu duo & image 1.7.2 trying to use an avertv volar HD DVBT usb tuner.
My tuner seems to have a similar response to the previous reply.
I know that the irish DTT service uses MPEG4 and the problem might lie there.
I was able to get the tuner working perfectly using windows media centre on win 7
Would anyone from The republic of Ireland have sucessfully used a UBB Tuner on the VU DUO
I would be interested in asking as I would probably then get one of those tuners.
out put of box dmesg command
dvb-usb: found a 'Avermedia AverTV Volar HD (A835)' in cold state, will try to l
oad a firmware
dvb-usb: downloading firmware from file 'dvb-usb-af9035-01.fw'
dvb-usb: found a 'Avermedia AverTV Volar HD (A835)' in warm state.
DVB: registering new adapter (Avermedia AverTV Volar HD (A835))
af9033: firmware version: LINK:11.15.10.0 OFDM:5.48.10.0
DVB: registering adapter 1 frontend 0 (Afatech AF9033 DVB-T)...
tda18218: NXP TDA18218HN successfully identified.
Registered IR keymap rc-empty
input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0/u
sb1/1-2/bh-rc/rc0/input1
rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0/usb
1/1-2/bh-rc/rc0
dvb-usb: schedule remote query interval to 200 msecs.
dvb-usb: Avermedia AverTV Volar HD (A835) successfully initialized and connected
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
P: Vendor=07ca ProdID=b835 Rev= 2.03
S: Manufacturer=AVerMedia TECHNOLOGIES, Inc
S: Product=A835
S: SerialNumber=0000000000000
I:* If#= 0 Alt= 0 #EPs= 5 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_af9035
E: Ad=86(I) Atr=01(Isoc) MxPS= 0 Ivl=125us
I: If#= 0 Alt= 1 #EPs= 5 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_af9035
E: Ad=86(I) Atr=01(Isoc) MxPS=3072 Ivl=125us
Palinkat
As I said the Aver A867 works fine for me in Ireland. I bought it cheap on Italian Fleebay, it's a SKY DVB-T blue stick. Angelo knows them well :) I live in Wicklow and get good signal even with aerial in attic.
I also read about tweaking the terrestrial.xml, posted here but was for TNT France but same logic should apply. I never tried as I sold the A835 to get A867.
Hope this helps
I also have a Sundtek Media Pro I am not using if you want to try.
angelofsky1980
oad a firmware
1/1-2/bh-rc/rc0
S: Product=A835
Ok you have an A835 stick compatible like my Aver Volar Green HD :)
If you use the latest BH 1.7.2 please install the IPK listed in THIS post (download the one for your box of course!) and reboot your box.
If you have already installed it.... I don't know what happen :(
CONOR
Hope this helps
I have solved my issue with my USB Tuner.
box: VU DUO
USB tuner: averTV volar HD usb tuner
iage 1.7.2
I found a link with manual tuner settings for the irish DTT stations.
they were:
For Irish DTT, do a Full Scan (Tuned) with these settings:
Freq. 738000000
Band. 8Mhz
Inversion. Auto
Constellation QAM 64
LP Coderate 1/2
HP Coderate 2/3
Trans. Mode 8k
Guard Interval 1/32
Hierarchy None
So I didnt need to change the tuner config file at all.
When I used these settings it took about 1 min to show all the channels.
The link to thr web page I found it on is : http://www.jeacle.ie/pub/articles/mythtv/
Thanks for all the help recieved.
