Hi to all,
Im new in the hole thing ;-) Also in Vu+.
I use a Vu+ Zero and have Installed OBH 0.1.
First time I connected to my Router I used an USB-Stick with rt2800 chipset. It worked but i had some lags. So i bought an Gigablue Stick with antenna and 8192cu Chipset and tried that one. OBH recognizes the stick. I can detect my Wlan connections and others but i can not connect. Results of a Network test are:
Networkadapter Wlan connection: ok
Wireless connection: failed
DHCP avtivated: ok
IP-Adress: not confirmed
Nameserver: not confirmed
I tried it a few times with the gigablue and connected then the rt2800 stick again. But now i have the same problem with this one. I can not connect any more.
Can anybody help me with this? This would be very kind. Thank you.
DHCP avtivated: ok
