sandralongleg
Hi Can someone test to get tunerserver channellist from a Blackhole image 3.0.3H installed on a Vu+ Duo2 and the Tuner Client is activated with IP address with OB 4.1 on a VU Zero box only by network cable and standard settings.
But still after saving and rebooted no channel lists is downloaded so no Bouquets or channels are available or downloaded from Tuenrserver automaticlly as it should.
How do I solve this. BEfore it worked fine to stream and fetch channels if I use Blackhole 3.0.3h on the zero box but there its som much EPG problems when using Tunerserver only on the Zero box seems better in forums that the OB image should work much better.
Please help.
Please help.
