Online Update Problem
Tried again just now and same problem. Also, fails when using Telnet (opkg update && opkg upgrade).
Currently installed image is OBH 4.2.045 and the box is Uno 4k. This problem has been going on since the last two online updates release.
I have checked my network connectivity and that is ok. Also, I have no issues with online updates with my other Vu+ Solo 2 box on same network.
My Uno 4K Has not been smooth on the last few updates, takes ages to install and reboot but it has worked.
Maybe try a fresh install, it is on my list of things to do.
I got the red dot about some updates of 4.3 for Solo4K (mine is in Flash) but:
I tried, as I always do, by telnet command but this time I got this message
Downloading http://feeds.vuplus-community.net/openbh/4.3/vusolo4k/3rdparty/Packages.gz.
Updated source 'openbh-3rdparty'.
Downloading http://feeds.vuplus-community.net/openbh/4.3/vusolo4k/all/Packages.gz.
Updated source 'openbh-all'.
Downloading http://feeds.vuplus-community.net/openbh/4.3/vusolo4k/cortexa15hf-neon-vfpv4/Packages.gz.
Updated source 'openbh-cortexa15hf-neon-vfpv4'.
Downloading http://feeds.vuplus-community.net/openbh/4.3/vusolo4k/vusolo4k/Packages.gz.
Updated source 'openbh-vusolo4k'.
Downloading http://feeds.vuplus-community.net/openbh/4.3/vusolo4k/vusolo4k_3rdparty/Packages.gz.
Updated source 'openbh-vusolo4k_3rdparty'.
Not selecting libavformat58 4.1.4 as installing it would break existing dependencies.
Not selecting libavdevice58 4.1.4 as installing it would break existing dependencies.
Not selecting libavutil56 4.1.4 as installing it would break existing dependencies.
Not selecting libavcodec58 4.1.4 as installing it would break existing dependencies.
Not selecting libswresample3 4.1.4 as installing it would break existing dependencies.
Not selecting libavresample4 4.1.4 as installing it would break existing dependencies.
Not selecting libswscale5 4.1.4 as installing it would break existing dependencies.
Not selecting libavfilter7 4.1.4 as installing it would break existing dependencies.
Not selecting libpostproc55 4.1.4 as installing it would break existing dependencies.
So, I tried by the GUI but, after the reboot, the same 9 updates were again available.
It's a new issue: maybe there's something wrong in the process.
Exact problem for me here.
In my case I did the online update on the flash image first followed by the one in OMB. Maybe the image sees files already installed and installing again would 'break existing dependencies'.
Just guessing.
Just guessing.
No: it's normal when you try and update images installed in OMB and it needs to update module alredy running.
But in this case I just and simply tried an update of the image in flash, not the ones in OMB.
I don't have that on Ultimo 4K.
After the update.
I installed the image (OMB ) a few days ago and made an update today.
Black Hole i flash.Open Black Hole in OMB.
Long time ago? The last update (with change of version's number) was last Friday, from 4.3.003 to 4.3.004. I'll try later today on Duo2.
But it seems an issue box-dependent, for what has been reported so far.
On zero4k im install image 4.3 when was out after install im daojf online updste when is out.
Last update was in friday like you write and this update was go ok was 77 files and was all update and version change .
Image working and all is ok.
Same problem today on Duo2, despite the fact it was still at .003: it performed the update to .004, then I tried again to update and it gave the same error (by telnet, of course):
So, at the moment we know for sure that the problem
AFFECTS Solo4K, Duo2, Uno4KSE, whilst we have different reports for Uno4K (Azam couldn't update, Artorious could);
DOES NOT AFFECT: Ultimo4K, Zero and probably Zero4K (I did not get, @bogdanm, if you tried again to update after Friday's .004 main update, because this is a new small update of the .004: as I said, the update from 003 to 004 goes well, the next doesn't).
It is the same with Ultimo4K and Zero4K (I think it will be all boxes tbh).
But I just tested ViX 5.3 and it does the same, so it's an OE-A issue and not an OBH issue.
The weird thing, I just noticed now and having two Zero 4K, one reports that there is an update and the other indicates that there is no update ...
