Online Update Problem
It is the same with Ultimo4K and Zero4K (I think it will be all boxes tbh).
But I just tested ViX 5.3 and it does the same, so it's an OE-A issue and not an OBH issue.
I confirm, upgrading UNO - I saw same logs, but everything is working OK.
No problem? There is the same problem (because now we know it's an OE-A issue). Didn't you notice that among the many "successful" lines, there are still the "wrong" ones? ;) For instance:
Not selecting libavutil56 4.1.4 as installing it would break existing dependencies.
and, as a matter of fact, after the update, if you try again to update, here they are, the 9 ones as before, lonely and visible ;)
  • Like
Reactions: KFL
No problem = box is working correctly.
OK, upgrade process is not clean.
I found in my logs that phrase "it would break existing dependencies" apperas for upgrades since 4.3.002.
I attached last clean upgrade 4.3.001->4.3.002
p.s.I make online upgrades since 4.2.xxx
