Open Black Hole 0.1 update 19-06-2015 Vu+ Solo
hi,
two questions,
1, when i restart my box dns address is not saved when im using static ip, on dhcp dns stays after reboot..
2, can i use skin from openpli4 ? the hd1 or hd2 ?
thanks
by
kikan
A question to be sure, you can install this on a Vu+ solo 4k?
No ... You have to wait for an OBH image SOLO4K release, don´t install this because this is for SOLO not for Solo4K, and if you attempt to install it, you can brick your SOLO4K and make it unusable.
Hi,
I have tried to update my Vu+ solo with open Black Hole without any success. I tried different USBs . The USB was formatted as fat32, yet when I power off the machine and put in the USB then power machine back on , the red light appears and then it turn to a pinkish colour and keeps flashing blue .Nothing happens after that , the system I was running was flushed . I tried rebooting it but I only got a blank screen. How can I rectify this problem? is there something I am doing incorrectly? . Your help with this matter will be greatly appreciated
Hi,
FUCKING CLONES ARE NOT WELCOME HERE.
if the problem I'm having is from clone please tell me how to discarded when I try to load open Black Hole it flashed all the data
What @angelofsky1980 are trying to say you, is that you own probably a "Clone" Vuplus STB, where a clone is an " NO ORIGINAL VUPLUS STB ".
If this is the case, you can't, or you aren't able to update your STB to a newest firmware ( Original or Blackhole ones ), or it will brick your STB.
Thank you nunigaia to find this I need to open my STB and check inside is that what I need to do?
Afaik Genuine Solo models do not have blue led's in them
so the one I have is a fake or clone I got it with the software and had it for the last 3 years for 2 years it was working ok but now some channels wasn't working that is when I decide to update and I did with open Black Hole all I get is blank screen I just brick it thank you all for your info
Yes it does sound like you have a clone box
Hello, a friend give me a solo to install a new image. I have the same problem, when i put a USB stick (i have try 2 differents). The led is Red 1 second and then the solo boot on the installed image.
I 've thinked on a clone too but if I've compared the clone/original pics and it's seem to be an original ???
So i have tried to flash blackhole 3.0 and it works. Do you think it's a clone ?
The BH 3 seem to work, the only problem found it's EPG. Impossible to load EPG Rytec France with CrossEPG or BH EPG (System menu). If I try a small one (BENL), no problem ???
Best regards
