Open Black Hole Vu+ Solo2 0.1
Hi!
I'm looking for a new image to install on my Solo2.
Now I've installed BH 2.1.7, but I've an issue with WinTV Hauppage stick. And it seems that I'm not the only one. Sound freezes every second. I think that image freezes as well.
Has someone tested it on this image?
Is there a great difference between 2.1.7 and this image?
I have a AVERTV VOLAR HD A835 and after the latest on line update the sound is choppy and also the video is. But if i press pause for a second (timeshift) and then again play the sound and video is perfect again until I have to change channel.
Tuner Server doesn't generate any channel list.
I have BH 2.1.7 installed in a VU+ Solo2.
I have enable Tuner Server and shared /media/hdd folder with my PC (the mount looks OK - green)
But the Tuner Server doesn't generate any channel list in /media/hdd/tuner.
Please any idea about what is happening? I am desperate reading everything about Tuner Server without a solution.
i have same problem with winTV ministick.
Today Ive tested OpeN Black Hole on Duo2, Solo2 and Solo SE ver2 - and I can not disabled the second infobar ?
In setting go on "none" saved with green buton , restart gui and after reboot the second info bar is again on enabled ?!?!?
On Open Blackhole 0.1 go to Menu > Setup > System > User Interface> by defaut second info bar is setted to 5s, set it to none and press <ok> or <GREEN> To apply your settings ... your second info bar must be disable!
Good morning everybody. Any new about the problem i mention? Will there be a fix?
Thanks
hi can any one help?
I am using open bh, my problem is i have sub titles all the time,
went to setup,,,, system,,, subtitle setting?,,,, and also, auto language selection,
no matter what i try, subs are still there,,
is there any way i can get rid?
thanks mick,,,,,,,,,,,,
Where did you have allways subtitles? What services channel? Sat or Cable?
I am using blackhole open,,,,
on sat tv,,,,,
on most channels,
do subs come as part of this open image, can I not turn them off?
On viewing one of those chanels, on your RCU press <yellow>, <yellow>, and see if you have any of the subported activated txt subtitles. If you have it, where it has an "X", press <OK>, and exit.
See it this make any sense.
thanks, that sorted it, no more subs.
I'm a new member in this community, and I would like to thank you so much for the great job.
You're simply the best BO/OBH team !
Hi, can i use in the Open Black Hole Vu+ 0.1 the ci module with sky v14 and doscam25 with internal HD Plus Card?
