Open Multiboot does not work
hello, I have vu + zero4k in flash openpli is installed, on HD it is on multiboot I have openatv 7.1, and openvision, I had some others that I used without problems but I could never boot from multiboot Open Black Hole 5, also when I had another IMG in the flash I couldn't boot Open Black Hole 5 again, so I tried to install OBH5 in the flash and in openbov 7.1 or another multiboot I could never boot any other IMG, so as I see it others have the same problem now the question is why or what is the problem because everything i tried without OBH 5 all work except with OBH5
I have got in my reciever VU + USB Turbo tuner - external DVB-T / T2 tuner from Marusys.
This tuner was supplied to me by my original VU + UNO4K SE dealer and it works perfectly in img Black Hole. It is not possible to tune in to T2 terrestrial television only in img Open Black Hole.
Now I have installed Oplen Black Hole 5 in the flash and I thought the problem with rotating the dish would be solved. It disappointed me. Again, it is not possible to turn, for example, from 23 E to 19 E, etc. I can't deal with that.
Is it the tuner, the firmware or you?
I become to not understand nothing!
What does a terrestrial or cable tuner have to do with a tuner intended for satellite reception?
There are two problems. 1. Image OBH5 does not see my hybrid tuner on terrestrial TV even if it is connected in the receiver as in BH3.1. 2. I have tuner A and B set the same as in BH 3.1, where there is no problem with rotating the dish. The problem with img OBH5 is that the dish does not rotate. I think that in VU + UNO4KSE the settings I had with the installation of other img via Open multiboot, for example img OpenATV, where there was the same problem with rotating the dish, remain in memory. I can't explain it any other way. It would like to delete all previous img settings in the VU + so that the receiver is completely clean. The factory settings will probably not solve this.
