Open MultiBoot How To install and use it
well before that i wanna ask you something,with openbh 0.1 can i use blackhole 3.0.9 on multiboot? it stucks?
Open Blackhole 01 is a very old version.
  • Use at flash Open BlackHole 4.2.018 ( without many plugins ... to not fill up your flash memory as you own Vu Solo ) and then install at Open Multiboot BlackHole 3.0.9, Open BlackHole 4.2.018 and install what you need there.
finally i made it!with openbh 4.2.018 doewsnt work...but with 0.1 works.i install satdreamgr on multiboot..blackhole 3.0.9 gives me black screen on openmultiboot again... i dont know the reason
I would suggest that you start all over from scratch
First flash latest OpenBlackhole Image (openbh 4.2.018)
Do an online image update and when done follow instructions from levi in post nr 1 of this thread
But before uploading the Blackhole image to folder open-multiboot-upload shorten the name of the zip file to only Blackhole before installing in multiboot.
This should work for you if done proper like in post nr 1 :)
That's the it works: only one can be in flash, of course. The other ones are in the device you choose (usb or hdd, if you like).
thanks! worked perfeclty. I followed step by step the guide and managed to install VTI image on USB at first attempt.
vu solo se v2 blackhole 3.08 flash kurulu multiboot imaj kurarken, sanal MTD cihazı oluşturamıyor--cannot create virtual MTD device,
uyarısı geliyor, kurulan imajlar:satdreamgr-egami kurulamayan birkaç örnek:vti14.06, PKT 7.1, blackhole 3.09
ham imajlar bunlar, backuplardan da kurulan open atv 6.4, kurulamayanlar aynı
üstad, dediğinizi yaptım. flasha blackhole 3.09 kurdum. multiboot pkt 7.1, open pli 7.3, openblackhole 4.3 imajlar kurdum. backup olarak opendroid kurdum ve hepsi çalışıyor.
size ait 2 adet vu solo se v2 için blackhole 3.09 L ve B uzantılı backuplarda aynı hatayı veriyor. size ait backupları kuramadım, çok kez denedim. imageversiyon dosyası force update dosyası no force dosyası ve splash dosyası gibi dosyalar hemen her imaj ya da backupda farklı durumda. bazılarında imageversion dosyası yok. bazı dosyalar 5 adet bazı backuplar 3 dosya bazı backuplar 6 dosya olabiliyor. sizin backuplar 5 dosya bunlar üzerinden yorumunuzu beklerim. paylaşımlarınızı kullanmak istiyorum. umarım bir çözüm buluruz.
saygılar
Kardes benim backup dosyayi zipden cikar ve bh orojinal imajindan kernel_cfe_auto.bin alip benim backpinkiyle degisip dosyayi tekrar ziple oyle dene
teşekkürler,
blackhole 3.09 orijinal imaj üzerinden kernel_cfe_auto.bin alıp, sizin L ve B backuplarda ki dosya ile değiştirdim. Zip sonrası yeniden openmultiboot yükledim,
biraz yükleme yaptıktan sonra oluşan hata: generic error in unpaack process
paket geri alma süreci genel hata
dosyalar: force.update, initrd_cfe_auto.bin, kernel_cfe_auto.bin, root_cfe_auto.bin, splash_cfe_auto.bin
