openBH 0.4 Vu+ SoloSE
Ev0
Admin
openBH 0.4
Whats New:
  • Completely new image
  • Based on OE-A core
  • Solo4K supported
  • Updated to Gstreamer 1.7.1
  • Updated to Python 2.7.9
Main Features:
  • MX HQ9W Full Hd skin (1920x1080)
  • Kodi 15.2 (Solo4K, Duo2, Solo2, SoloSE)
  • OpenMultiBoot (Solo4K supported)
  • OE-A Plugins
Black Hole:
  • Blue panel
  • Green Panel
  • Extra Settings
  • Addons panel
  • Compatible with OE-A and PLi plugins and Skins
What is openBH ?
It is an exciting project from the same team that produce the Black Hole images.
This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support, OpenGLes Animations and we have included Kodi 15.2.
As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
Do I have to upgrade to this new openBH image ?
No you don't have to upgrade to the new openBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
What about the Black Hole and Black Hole Prism Images ?
For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new openBH image is an additional project and we are fully committed to all images.
Where can I find the openBH git ?
The openBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
USB DVB-T Avermedia A867. It is not detected
I cast as the previous version but it does not work
Telnet should also need to run the following command:
code:
opkg install kernel-module-af9033
restart
code:
opkg install kernel-module-mxl5007t
angelofsky take care
Thanks. Great work.
Do you know why exodus and specto aren't working. They're installed correctly, but when opening streams, both give errors.
I don't know if I'm the only one with this problem but after I change root password via telnet, I can't login via ssh as root. I can ssh login with other users that i created but not with root. Dropbear issues or user issues? =P
Hello my Friends. This image 0.4 is amazing. But I have one question. How to get 2nd info bar display automatic with 1st info bar (Together at the same time), when I change canal ?, so I mean, without second click to get 2nd info bar display.
VU+ Solo SE Dual DVB S2.
Thanx in advanced!
Thanx in advanced!
You can't.
Well I want to know if this image has multiboot for vusolose v2 and if that does not work one could put this image in the openmultiboot of BH.
For me it is inprecindible the openmultiboot because I want to be able to test different images.
Thank you very much.
The new image does not show (accept) the original external VU DVBT tuner. The OBH 0,1 series shows the internal DVBS2 and external DVBT tuner.
