openBH 0.4 Vu+ SoloSE
Does Kodi's AirPlay work in openBH 0.4 (on Solo SE)? If yes, must Kodi run (in the foreground) for AirPlay to work, or does it suffice to have the Kodi-AirPlay-Service running?
Since ever I am looking for an Solo SE Image that supports AirPlay... openBH may be the ONE ;)
Thx in advance!
Why on VOD movie IPTV the 3-6-9 button does not work?
If I use it on local movies file all works perfectly.
Please help
I keep meaning to switch to this image but reluctant because of all the little niggles, anyone using this on a DVB C tuner????
Hi
Thanks for a very nice image
There is an issue; the second info bar shows some random/wrong frequency, at your second picture in the first post it show the frequency for ZDF HD at 13777 MHz when it should be 11362. It is possible to fix it?
Regards
Iradj
Thx for this..
But!! im a newbie with VU, so how long will it take from you start the box with the usb untill it ready to use?
Thx for this..
If you have the needed tools:
  • FTP tools with telnet ( Dreambox Control Center ) or VuCC
  • WinSCP with putty
  • Dreamset or DreamboxEdit
  1. 4 or 5 minutes to flash a new image.
  2. It requires about 5 or 10 minutes to have it in order ready to use. This is variable, depending of the complexity of your Sat / cable or both system.
