OpenBH 0.6 Vu+ Solo4K
You have to install Kodi from the Speed Up panel (press blue twice, or go menu - BH Apps and then Black Hole Speed Up panel
You can not online update from OBH 0.4 to OpenBH 0.6, you have to reflash (or put into omb).
OMG, I cannot believe it. Again I need to flash from scratch (never had a lot of success with personal backup, although I'll try again...).
I do not know how successful a personal backup will be either as 0.4 and 0.6 use different OE core versions and also different E2 versions.
Now hbbtv works.But i think the Remote keys in 0.4 oe 3.2 are better placed why they Changed?
And there is a limit 480 for 3/6/9 keys to Jump
Its much better without limit in 0.4 and as it is in ATV or Black Hole 3.2
Now hbbtv works.But i think the Remote **** in 0.4 oe 3.2 are better placed why they Changed?
And there is a limit 480 for 3/6/9 **** to Jump
Things change, thats life.
If you prefer to use 0.4 then use 0.4, nobody is forcing you to use 0.6
I started having crashes as soon as I just choose the BlackHole Apps in main menu and I believed it had to do with L4L.
Instead, I found out that these crashes are due to the last online update.
In fact, starting from a perfectly running full backup made on 3rd Aug, everything works fine. As soon as I perform the online update, it start crashing just the way I described.
It has already been fixed, and you will be fine with the next online update
Actually, that menu's item is now OK but crashes when you try to use the plugin SOFTWARE MANAGER and choose update. The responsible seems to be SoftwareUpdate.py:
[omissis]
< 7333.464> File "/usr/lib/enigma2/python/Screens/SoftwareUpdate.py", line 163, in __init__
< 7333.467> IndexError: tuple index out of range
< 7333.467> [ePyObject] (CallObject(<bound method NumberActionMap.action of <Components.ActionMap.NumberActionMap instance at 0xaa8f6f80>>,('WizardActions', 'ok')) failed)
[omissis]
Very strange as I did an online update this morning, and it is fine for me
Yes, I did it as well but starting from the main menu (Configurazione/Aggiornamento software, in English I suppose it'd be Settings/Software management)
But trying the same from the System PLUGIN "Software manager", it crashes.
Edit, after changing some settings, I can confirm same crash.
I will look into it.
EDIT: fixed the issue, should be fine in the next update.
Today morning it was not possible any online update, both from main menu and from the Manage Spftware plugin.
So, I found that it's possible to perform the update by this command
opkg update && opkg upgrade
Is it right? It seems it actually did because now OBH says there's nothing to update.
Again the same problem.
Is it needed to remove some files before the manual telnet command. I think I read something about this.
network browser freezes my box
..update .. now it works .. sorry for the post (can't delete)
