OpenBH 06 DUO2 update "online" stucks on booting
just updated obh 70 updates waited for screen to boot black hole stuck on it nothing happening
Your information is to short.
We need more information, as:
  • STB Model
  • Image used in flash
  • Are you using OpenMultiboot? Wich image are you running this side?
  • You have tried to update image when was running in OpenMultiboot?
sorry vu duo2 open black hole no run openmultiboot
Can you please test, by reflashing only with this file, and see it fixs ... the booting.
Proceed as a normal "flashing process".
1) Unpack the zip attached file to a folder on your PC.
2) Copy the vuplus folder to the "root" of your USB pen drive.
3) Turn off your DUO2 ... disconect all USB devices ... and insert the one that contains the files, on the the front USB SLOT.
4) Turn on your DUO2 ... and Press the power button on the front door...
This is a quick process ...
Try it and reply.
I just had same problem after the update even without USBs devices attached and was a fresh installation.
Thanks for any help.
Yes,same here my duo 2 hangs when it when tries to update the image.The same happens when a fresh image is installed.
