OpenBH 06 DUO2 update "online" stucks on booting
Tuner Vu + Duo OpenPlackHole 0.6 after the last update image already will not start. It stands on starting
Only for VuDuo2 STB´S.
Post your information, and please don´t mix information related to other STB´s models.
For that, open a new thread regarding the STB model you have and image used.
Thanks,
Good evening.
I have a similar problem, after the online upgrade depends on prompt "BlackHole".
Please tell me when to fix the problem?
Receiver VU+ DUO2.
There seems to be an issue with the OBH feeds. We are looking into this, and will let you know when the problem is resolved.
ok thanks for the info will it be [possible to use a usb to flash any up dates say onse a week besides the online updates if that would be possible regards
