OpenBH 1.0 Vu+ Solo2
It seems there was a bug in OBH 1.0.001 (the first release) that was not present during testing with full backup.
It has been fixed in 1.0.002 however it seems the fix does not come through via online update for some reason.
Therefore the only option to fix, is to download the new file (attached to release post) and reflash the box (you can use a settings backup to make it quicker to setup the box again).
1_0_16_1c34_2b_46_e080000_0_0_0-jpg.28492
with blackhole historyzap is working.
but with obh any way to use historyzap selector like above pic?
Im no sure about image to solo2 but on uno4k work very good in OBH
The settings back up from 0.6 are not loaded in the 1.0 open blackhole. Neither in Vu Uno 4k nor Vu Solo 2. The message displayed says something like this ' not compatible with the current version". I am waiting for new version of open blackhole which has the same architecture as 0.6 image version. Regards
You must reflash your STB from scratch!
Before that, you can backup your settings ( sat lists ), by using dreamset, dreamboxedit, etc ( settings managing tools ), to apply it after reflash.
Thank you very much for such fast response. I have tried to reflash afresh many a time but to no avail. I have used back up settings tool of vu plus models as well as Dreamboxedit.
Thanks team for this image
Right now I'm using Blackhole image, witch is the best for me, and actually I'm using the Teleportation option with different universes, so that I have a large space to use for many more plugins. I'd like to move to openblackhole, but I don't know if the teleportation option exists in this image, and if I can use it as like in BH image. So please could someone help and give me an answer please. Thanks for the good Job
Best regards..
I installed the obh 1.0 image, but I get a tuner error in half of the channel list. I do not get this error in other images.
I have the same problem in Vu Uno 4k as well as By Solo2. 0.6 image is ok. 1.0 open blackhole image also does not accept back up settings. I am anxiously waiting for next iteration of open blackhole.
Thanks bala240 i will wait for the new image
I also have the same problem. Scanning - the signal is! Begin to see the error tuner not configured.
HEllo i have a problem i cant update my image what is problem ??
reciever show me that problem rietreving data from vuplus-community site and try later my connection are ok in to internet and ....
By telnet try the following commands ( one by one ):
opkg update && opkg upgrade
reboot
