OpenBH 4.1 Vu+ Duo
Ev0
Admin
OpenBH 4.1
1-png.33196
Whats New:
  • Updated to OE4.1 core
  • Updated to Python 2.7.13
  • Updated to Gstreamer 1.13.0
  • Glibc 2.2.5
  • GCC bug fixes
  • openSSL Security fixes
  • Basis for new 64 bit environment Support for multi libs 32/64 Bit
  • Stability updates
  • Based on OE-Core Morty
  • MX BlackShaddow_P Full Hd skin (1920x1080)
  • Kodi 17.6 (for those models that support it)
  • Various OE-A Core updates
2-png.33189
3-jpg.33191
4-jpg.33192
5-jpg.33195
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
I don't think there will never be a NEW file (not an update: they are two different things) because
4.1.xxx arrived to .035 by online updates.
Only for the more recent boxes is being developed the 4.2.
i have a question from dear admins
did you have any program for support HD models like DUO in future ?
if you don't like to SUPPORT HD models please write us in here for Us
THANKS and Regards
The VU+ Duo 2, and Solo 2, are HD models, as well as others, and are still supported.
It's just that your receiver is too old, for the latest images, as there isn't enough power to run the latest features, including KODI, it doesn't mean that you can't still use your VU+ Duo, as the last Black Hole, and Open Black Hole, will still work perfectly well.
It seems pointless loading the latest image, or any future images, which will only slow down your receiver.
THANKS and Regards
Reading you, one might think there is a huge difference between 4.1 and 4.2. Imagine that I'm still using 4.1 in my Solo4K, installed in omb, because there are new issues in 4.2. Every now and then I load it from flash to check if the new updates have solved its issues.
So, it's quite inappropriate to think you can only use your old box by the last image. Do you use Windows20 on a PentiumII-based computer or MacOs 10.14 in a clamshell Mac from 1999? IT evolves, that's the only sure thing. OBH 4.1 is a great image: enjoy it.
