khafanpardaz
Reading you, one might think there is a huge difference between 4.1 and 4.2. Imagine that I'm still using 4.1 in my Solo4K, installed in omb, because there are new issues in 4.2. Every now and then I load it from flash to check if the new updates have solved its issues.
So, it's quite inappropriate to think you can only use your old box by the last image. Do you use Windows20 on a PentiumII-based computer or MacOs 10.14 in a clamshell Mac from 1999? IT evolves, that's the only sure thing. OBH 4.1 is a great image: enjoy it.
Due to the contempt of the present government of the United States against my country, the value of our money is very low. I am a simple worker. I can not afford the 4K receiver. Due to our Internet filter, I do not have access to your panel
And thousands of other problems have caused my backwardness and my country
Please keep support for the old HD receivers with the same version 4.1
Do not splash on our wounds
We are not the ones who are today's troubles and are looking forward to the future
This text has been translated by Google
I'm sorry if it's a mistake
thanks to all dear admins and any one do help us
