OpenBH 4.1 Vu+ Duo2
Ev0
Admin
OpenBH 4.1
1-png.33196
Whats New:
  • Updated to OE4.1 core
  • Updated to Python 2.7.13
  • Updated to Gstreamer 1.13.0
  • Glibc 2.2.5
  • GCC bug fixes
  • openSSL Security fixes
  • Basis for new 64 bit environment Support for multi libs 32/64 Bit
  • Stability updates
  • Based on OE-Core Morty
  • MX BlackShaddow_P Full Hd skin (1920x1080)
  • Kodi 17.6 (for those models that support it)
  • Various OE-A Core updates
2-png.33189
3-jpg.33191
4-jpg.33192
5-jpg.33195
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
by backing up version 1.0 data, can I transfer that backup to this new version?
in italiano
facendo un backup dei dati della versione 1.0, posso trasferire tale backup su questa nuova versione?
No, they are different versions and upon installation it will inform you that they're not compatible.
You can save your channels, and Bouquets, using dreamboxedit, or dreamset, and your Kodi information should be restored.
the top of the images none exceeds this image.
one could only improve the pause part and advancing in the flows.
good good the team
