OpenBH 4.1 Vu+ Duo2
Incredible ! This image have not WLAN Connection in settings, instead it has 2 x LAN Connection to Internet settings. How to set WLAN (wireless) Connection ???
It should have WLAN first and LAN second, something has gone wrong during installation.
Did you try to set it up on installing Open Black Hole 4.1 or later in Network?
Did you do a fresh installation, in the flash memory, or are you using multiboot?
Did you try to install a backup version?
It would help if you supplied more detailed information.
