OpenBH 4.2 Vu+ Duo2
Ev0
Admin
OpenBH 4.2
1-png.33196
Whats New:
  • Updated to OE4.2 core
  • The main packages and utilities have been updated:
  • Gstreamer 1.14.4
  • Libc6
  • Openssh
  • Busybox
  • Samba
  • Openssl
  • Nfs Util
  • Dropbear
  • Bitbake
  • Gcc 6.3.0 Memleak fix
  • Based on OE-Core Roki
  • Various OE-A Core updates
  • Various Skin Updates from Mx10
2-png.33189
1-png.39763
2-jpg.39633
3-png.39762
6-jpg.33190
7-jpg.33193
8-jpg.33194
Where can I find the OpenBH git ?
The OpenBH git is located here: https://github.com/BlackHole
Thanks to:
  • Rytec, doglover and all the teams that host EPG feeds for EPG Importer, for their continued support.
  • All developers for their plugins used in the feeds of this image.
  • All of the BH Beta team for their hours of testing and dedication on improving the image.
  • All those who have submitted patches/fixes
  • To all who have submitted translation work for OpenBH.
  • Huevos for his work on blindscan and ABM.
  • Peter de Jonge, abu baniaz & Huevos for their work with Andyblac to improve ABM.
  • Matrix10 for OpenBH skins.
DISCLAIMER
THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
Updated all skins Open Black Hole image 4.2 ,download from images download server
Added new panels
Added more information
Fixed minor bugs
(green button >> yellow >> Addons Download Manager >> Open Black Hole Image Skins >>> ver (4.2 / up)
Mi potete dire se faccio un backup della 4.01 a questa 4.2, esiste compatibilità, o come le altre è stata scritta con codice diverso per cui un backup non si può ripristinare?
Naturalmente parli del backup delle configurazioni: no, se n'è già parlato in altri post. Non è riutilizzabile e infatti non lo farò mai più. Faccio prima a mano. Salvati i canali e, semmai, tutta la cartella /etc/enigma2 dove ci sono file importanti (a cominciare da "settings") e poi trovi i timer, gli autotimer e varie altre cose riutilizzabili.
Siccome questa è la sezione internazionale, dobbiamo usare l'inglese (ma se ti servono altre info, c'è la sezione italiana di OBH)
Obviously you are talking about Personal backup: no, it has already been discussed elsewhere. It is not compatible and for this reason I won't loose time with it any longer.
Save your channels and, in case, the whole folder /etc/enigma2 where you have many important files (starting from "settings") and where you find timers, autotimers and so on.
Good morning
The updates introduced in the latest Black Hole image 3.0.8.A will be extended to the OBH?
Thanks
Hall
Which updates are you talking about? Apart from possible driver issues (in case) BH and OBH are completely different images, based on different cores. So...
As explained by Ev0, In Obh you can seek using left / right buttons, but if you like to use the classic way here is a solution,
This file is for all the box but warning is only for current OBH version.
Unzip
Backup your original file /usr/lib/enigma2/python/Screens/InfoBarGenerics.py
Upload in /usr/lib/enigma2/python/Screens overwriting the original
restart e2.
Hi Shiro
Thank you for your suggestion, but on my folder can't found InfoBarGenerics.py but .pyo like on attachement
Thanks
Hall
Thank you very much Shiro
It also works the pause also the functions back and forth using the arrow buttons !
Hall
