OpenBH 4.2 Vu+ Duo2
Since there is no GreenScreen just an error message there might not be an Craslog?? and as Ev0 writes its pretty self explaining "No media/hdd .......... could be found"
So problem is, there is no HDD in the path or HDD is bad, maybe a mount problem so please check your mountpoints
by pressing BlueButton>>BlueBotton>>choose device manager from menu and check if you have any HDD mounted.
If you have no HDD but one UsbMemorystick mounted as HDD it could be that this mountpoint is lost and you have to re mount your storage device
and in Backup Manager choose the correct storage device for backup image location.
Post your crashlog not half a photo of the crash.
But from the bit I can see:
Error: No such file or directory /media/hdd/imagebackups/
Hi, now with the last update OBH 4.2.043 my decoder not go in crash, but when I try to backup the image it gives me only some errors but it doesn't create me log files, i such file or directory/home/root/logs but it is empty! What i should to post?
Ok I solved my problem I took 2 folders of the version OBH 4.2.041 and I put them in the version OBH 4.2.043 and after rebooted the receiver,
I made the backup without problems.
Attention this problem occurred with my vu+duo2, while with the vu+zero 4k I had no problems.
The 2 folders I replaced must be inserted:
usr/lib/enigma2/python/Plugins/SystemPlugins/ OBH
usr/lib/ python2.7
usr/lib/ python2.7
