OpenBH 4.3 Vu+ Duo2
Not in my case (Solo4K). I also installed it at my parents' Duo2 and I was able to change some settings. Maybe it doesn't like some specific setting, not all of them?
Hi, after updating to OpenBlackHole 4.3.014, upon rebooting my Vu+ Duo2, Zero and Zero4K remains blocked and I discovered that it no longer works with the Skin-DarkSky-HD-V1.0-MOD-By-RAED, considering that there is no original version of Army DarkSky for OBH, I would like to continue using the version MOD-By-RAED, thanks in advance for any response.
You won't find any support here for RAED modded skins.
I suggest you either use a different skin, or a different image.
Ok, I ask if in the future it is possible to have the Army Dark Sky skin in OBH too, considering that OpenBlackHole is also an original image?
You must ask this to the skin's author. A skin is not a passive component: it's not just a layout. It heavily interacts with the image's code, instead.
So it must be perfectly compliant to it.
Unlikely as Army has been away for a while now and he didn't update the skin before he stepped back.
menu3-jpg.47993
i try whit change image but in non open image i cannot see this options
how to fix ?
Can you please post images, of your menu options.
Your Network options look nothing like Open Black Hole, unless it has something to do with the skin, you're using.
Are you running multiple boot up options, and have Open Black Hole booting from a USB stick?
i use any different image 'non blackhole
problem continued and no wifi detected
No, you are using Open BlackHole. ( version 4.3.0.16 I).
1) Disable LAN
2) Push wlan connection and search for Wifi
3) After the Wlan searching, if any, set it with the needed parameters.
Note: There´s none issue with Wllan ( on Duo2 ).
