Vu+
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
OpenMultiBoot SSD
Discussion in 'Newbies Questions & Infos' started by Nicola1980, Oct 12, 2021 at 6:42 PM.
  1. Nicola1980
    Nicola1980 Vu+ Newbie
    13
    Since I upgraded BH to version I the OpenMultiBoot plugin no longer reads the SSD, I have tried with USB but it works fine. I also tried to initialize the SSD, but it didn't work ..
  2. Alexwilmac
    Alexwilmac Vip
    6,372
    You didn't tell us which image you are talking about: BH used to have some problems at recording in the same disk I use for OMB, OBH never had this problem.
    But, I repeat: the problem is not recognising the disk, only recording, in case, when BH runs from OMB. But I haven't tried last 3.1.0 if the problem is still present.
  3. Nicola1980
    13
    Yes it is the Black Hole...
    Duo4KSE
  4. dpeddi
    dpeddi Administrator
    133
    The ssd Is connected internally to the sata connector?
    Which box you are using?
    You mounted and configured your ssd using device manager?
