I couldnt save on DCC that file, because it was a symlink so i deleted guessing i could create after.
Now i tried to create new Symlink with DCC with the same exact name and the call and it doesnt show up on the folder after i click OK to create
How can i create, its not a file its a symlink i couldnt save it and now i cant create it, can you give a telnet command to create one?
The VPN (server side) gives me a small error, and i think its the process starts before the transponderdate is cached on the box.
Check the logfile timestamp makes a small glitch that i wanted to be corrected on future updates. This makes a small error on VPS on start but it maintains the link
VPN (server side) error
The trick i think is to delay the openvpn start script to be run after the transpondertime is set.
Is this possible?
