Pc streaming is working using E-channelizer but not in Openwebif
o_torrents
Dear all,
I have a doubt about streaming ports in duo2
Why I stream a channel using E-channelizer works and doesn't works using Openwif ?
I tested the stream first trying the openwebif when the duo2 are been restarted or firstly trying E-channelizer. Always the same result.
Is there a config file to investigate the streaming port?
Thanks !!!
o_torrents
when I change my port from 8001 to 8002 in Transcoding setup plugin, the streams to both tablet, pc (openwebif and e-channelizer) work.
I have both ports opened in my router
Some times a info appeared : PC streaming is replaced with mobile streaming. At this time, the stream port returns automatically to 8001.
