Persian Palace Clean 8 By Persian Prince (Enigma2-OE1.6-Mipsel)
Persian Prince
Release Date : 9-September-2011
Published By : Persian Professionals Team
Script Manager
- Swap Manager
- Mount Manager
-- USB
-- HDD
-- Mount
-- Format
-- UnMount
- Update Modules
- Delete Crash Logs
- IPK Server Manager
-- Size Check
-- MD5Sum Check
-- SHA1Sum Check
-- USB
-- HDD
- Picon Path Manager
-- USB
-- HDD
- Plugin Path Manager
-- USB
-- HDD
- Software Informations
-- Date
-- Swap
-- System
-- UpTime
-- Activity
-- Host Name
-- Process List
-- File Systems
-- Kernel Version
-- Kernel Informations
-- Installed Packages Informations
- Hardware Informations
-- CPU
-- MAC
-- Memory
-- Free Space
-- Free Memory
-- Kernel Modules
-- HDD Performance
--- HDD Status
--- HDD Temperature
--- HDD Informations
-- Internet Performance
--- Ping
--- Netstat
--- NS Look Up
--- Trace Route
--- Reset Network
--- Use Open DNS - Temporary
- Timeshift Path Manager
-- USB
- Time Update
- OPKG Update + Upgrade
- Persian Empire By Persian Prince - After Update Scripts
-- Fix Spinner
-- Fix Boot Logo
-- Fix Ajax Loader
-- Fix WebIF - Xtrend
-- Fix WebIF - Vuplus
-- Fix Remote Pictures - Xtrend
-- Fix Remote Pictures - VuPlus
-- Fix Remote Pictures - DreamBox
-- Fix Enigma2 Settings - Xtrend
-- Fix Enigma2 Settings - VuPlus
-- Fix Enigma2 Settings - DreamBox
Backup/Restore
- Plugins
-- Restore
-- USB
-- HDD
- Skins-Picons
-- Restore
-- USB
-- HDD
- Enigma2 Settings
-- Restore
-- Backup
-- Backup With Date
-- USB
-- HDD
- Restore Skin.XML Backup
- Restore Language Backup
Channel - Settings Downloader
- RR Settings
- Dona Settings
- Likra Settings
- Cyrus Settings
- Rytec Settings
- Cajton Settings
- AdelSat Settings
- Vhannibal Settings
- Farshadmb Settings
- Remove Channels - Settings
-- Remove Settings
-- Remove Channels
-- Reset Factory Defaults
- Data Channels Converter (Sky 19.2E)
Satellites-Terrestrial XML Downloader
- DVB-C Official (cables.xml)
- DVB-C PaphosAL (cables.xml)
- DVB-S Clone (satellites.xml)
- DVB-S Gemini (satellites.xml)
- DVB-S SatXML (satellites.xml)
- DVB-S SatHunter (satellites.xml)
- DVB-S SatLoader (satellites.xml)
- DVB-S FastSatFinder (satellites.xml)
- DVB-S By Persian Prince (satellites.xml)
- DVB-T Official (terrestrial.xml)
- DVB-T By Persian Prince (terrestrial.xml)
Persian Tools For Persian People
- Persian Weather
- Tehran Traffic Map
- Persian Language Adder (Translated By Persian Prince)
Cleaner
- USB
- HDD
- Temp
- Key
Installer
- USB
- HDD
- Temp
- Xtrend Drivers-Modules - ZIP
-- ET5000HD
-- ET9000HD
- DreamBox Drivers-Modules - IPK
-- 7025
-- 500HD
-- 800HD
-- 7020HD
-- 8000HD
-- 800SEHD
- VuPlus Drivers-Modules - TAR.GZ
-- Duo
-- Uno
-- Solo
-- Ultimo
File Extractor
- IPK
- NFI
- ZIP
- RAR
- TAR.GZ
Font Changer (DejaVuSans 2.33) - Supports 42 Fonts
- Bold Font
- Normal Font
- Read Me Before Do Anything !
Default Channel Audio Configuration
- English
- Persian
About Persian Palace
- Informations
- Last Server Update
- Upgrade To Latest Version
File Hashes
File Name :
enigma2-plugin-persianpros-persianpalace-clean_8.0_mipsel.ipk
CRC32: D513E6EC
MD5: 3CB258B7C63C952839626A05D528DCA6
SHA-1: FF23A9A21FA7F1AB8A5CE17374754305A2DAC7BA
ChangeLogs
- New Release With New Name "Persian Palce"
Help - FAQ
You Can't Upgrade From Previous Versions
Don't Install It If You Have "Prince's Panel" Installed
Remove Previous Versions With "opkg remove --force-depends enigma2-plugin-persianpros-princepanel-clean" Command
Comments & Requests :
Link Removed
Questions & Problems :
Link Removed
All 1.x , 2.x , 3.x , 4.x , 5.x , 6.x , 7.x Versions Are Outdated/Unsupported
Please Remove Them From EveryWhere , Thanks In Advance
Isn't It Nice That "Persian Prince" Always Brings New Features For You ?
ScreenShots :
Link Removed
Informations :
Link Removed
Feel Free To Contact Me : Email Removed
You Can Provide Direct Links For Settings , Satellites.XML , ...
I Will Add Them To The Next Version
Good Luck
Link Removed
Link Removed
  • enigma2-plugin-persianpros-persianpalace-clean_8.0_mipsel.ipk
