Picture in Picture diseqc
kralj
i have 6 Lnb (diseqc 1.1) but my PiP works only on one satelite.
if is chanel on astra PiP works only on astra if i change to thor i have tuner faild.
if is chanel on hotbird PiP works only on hot bird if i change chanel to eurobir i have tuner fail.
Matrix10
Do you have only one cable connected to one tuner ?
How do you think to watch two different satellites with one cable
and one diseqc ?
paolino
Vu+ User+++
You have to change your LNB's for DUO and add other Diseqc 1.1 with separate cable. Otherway it will not work.
kralj
diseqc it is on all satelit 1.1 and all satelit works perfect ,only problem is when is PiP on.
paolino
Vu+ User+++
Did you read what Matrix10 wrote? When you select a channel on satellite, Diseqc selects that one, which you are watching. And THERE IS NO WAY to give a signal to your box from other in your actual configuration.
Try to do a record from Astra watching HotBird. You will have same Tuner Fail error.
I gave you a solution. So it's up to you.
