Pitere
Thanks for reply, indeed I installed firstly dvdplayer and then hotplug from server. But the message is that hotplug could not be installed. I tried to install hotplug (ipk file) bymeans of telnet without any success. It is any possibility to have zip file to perform the installation manually? Could someone tell me which file must be deleted to unistall manually dvdplayer, to try for a new installation? I did not found the possibility to unistall the plugin from image.
The image is BH 1.3.9 including 1.3.9.2 upgrade.
Regards
Regards
