Hi Guys,
I am in desperate need of help. I recently purchased a VU+Duo2 with 4 tuners. To replace my wifes Humax Foxsat and my HD Skybox. All good, no issues. Installed a 2Tb WD20EARX HDD, great.
I would like to get used to the box first before I attempt to delve into it's inner depths and see what it can do.
Basically I would like to watch / record FTA channels with a simple channel list to make things easy to operate, the simpler the better.
I have tried to download a Black Hole image 2.0.9.1 onto a 256Mb stick and flash it onto the box, with no success. I followed the instructions, everything seemed to be going OK, but there was no differene.
The box is currently running the following:
Version: Sept13 2013-VUplus_experimental_factory
Image: Experimental 2013-09-13
Front processor version: 0
Detected NIMS:
Any help will be much appreciated, thanks.
Detected NIMS:
