please help me to put my iptv list in kodi blackhole 3.0.2
bibich20
Hi for all
i have blackhole 3.0.2 Kodi in my vuplus solo 2 and i want put my iptv list there
when i want enable tv setting i get this msg
" you need a tuner backend software and an add-on for the backend to be able to use pvr ""
any one can help me please or just give me the method how to install it ?
thank you
harddriver
Hi
In this Massage also Stand :
More Infos at hxxp://kodi.wiki/view/PVR
did you do that ? did you also go to the next Page ?
hxxp://kodi.wiki/view/VUPlus
and than did you go to :
hxxp://kodi.wiki/view/PVR/XBMC
No ? than i would recommend you to do that
Yes ? are you followed the instructions from there ?
if yes again and it does not Work,Sorry than i have no other Solution as :
Install streaming ( IPTV ) Channels by using a Repository like SuperRepo
there are more than enough to explore
