Hallo,
habe das neue bh image installiert,
wollte nun das plugin partnerbox vom feed installieren, ging auch, das plugin wird aber nicht unter Erweiterungen angezeigt.
woran kann das liegen
mfg
zp
Once you have used the partnerbox setup, you can access the partnerbox menu by long press on epg and then select "Partnerbox: RemoteTimer". This can be used to set a remote timer.
I cannot get the standard timer working with its "Remote Timer" entry I get a "400m bad request", if any one know how to get this working I would appreciate it.
