Plugins Updated tested
I have older version on my PC-HDD ( enigma2-plugin-extensions-fritzcall_experimental-cvs20100514-r0_mipsel.ipk ) , fine on VU+ Duo with aktual Image.
Sherlock works,
EMC 110 works,
Boot-delay-plugin works ( for Samsung HDD ).
Is there a way that Blackhole will get the possibility to auto chose a language for subtitles and audio? Now nothing is remembered and that is far from handy. OpenPLi have that and it is great.
Makek your settings for each channel and then restart enigma2, and settings will be saved!
I still have problem with google map and get " No images on this zoom level " error. Why this message?
I agree with U, had this issue with my other STB boxes, I thing something to do with the Plugin it self not the image or the STB box!
Thanks a lot. Unfortunately, even with the 2nd fix, videos start to play but almost always freeze, or loose sync with the audio. Is there an alternative plug-in for YouTube?
I do not have this problem.
I tested MyTube HD and it works great.
I think the problem is the speed of your internet / server
or local network.
If I can see a dozen HD movies then the problem can not be VU and MyTube.
You can test on HD with Nvidia PureVideo HD 1080p Test movie.
Of course all this depends also on how busy is MyTube server ,
but I tested with twenty HD movies and work great.
New version Web Media v 3.1 from pcd on our image server
Author: pcd
YouTube
DailyMotion
MyVideo
SVTPlay
TurkWebTV
MetaCafe
ClipFish
ZDFMediathek
ARDMediathek
AdultVideo :
YouPorn
PornRabbit
Tube 8
Please use Config in the first screen to configure cache folder. You can also configure if download should stop at Exit from the plugin.
Downloads will be in folder webmedia inside cache folder. For SVTPlay - the download will be in folder svt inside cachefolder.
Adult Video Logo Show/Hide with Config in the first screen. Enable/disable is via Menu button. Save and Exit and start the plugin again.
Thanks pcd for nice plugin.
With Webmedia 3.1 plugin configured with the adult video=yes, when i try to acces the Adult section of the plugin i get a message: Adult content is disabled! Can anybody confirm that it's working, or is there something else that needes to be configured?
