bigcat
Hi Everyone,
I'm trying to store an updated position for 1°W and not having any success.
The stored position is a little off, so I went into Positioner Setup and using Positioner Fine Movement, tweaked the postion until the SNR peaked. I then arrowed down to Positioner Storage and pressed the green button (Store position), but when I go back to the main menu and try to view the signal, I can't - the SNR is at about zero.
I have a second RX connected to the second LNB feed (but not controlling it) and on that I can see that when I'm in Positioner setup mode the signal is stable and locked. But as soon as I go back to the main menu on the Vu+, I lose lock on the second LNB feed as well.
Can anyone suggest what I'm doing wrong?
