Persian Prince
Prince's Panel Clean 7.1 By Persian Prince (Enigma2-OE1.6-Mipsel)
Release Date : 10-August-2011
Published By : Persian Professionals Team
Script Manager
- Swap Manager
- Mount Manager
-- USB
-- HDD
-- Mount
-- Format
-- UnMount
- Update Modules
- Delete Crash Logs
- IPK Server Manager
-- Size Check
-- MD5Sum Check
-- SHA1Sum Check
-- USB
-- HDD
- Picon Path Manager
-- USB
-- HDD
- Plugin Path Manager
-- USB
-- HDD
- Software Informations
-- Date
-- Swap
-- System
-- UpTime
-- Activity
-- Host Name
-- Process List
-- File Systems
-- Kernel Version
-- Kernel Informations
-- Installed Packages Informations
- Hardware Informations
-- CPU
-- MAC
-- Memory
-- Free Space
-- Free Memory
-- Kernel Modules
-- HDD Performance
--- HDD Status
--- HDD Temperature
--- HDD Informations
-- Internet Performance
--- Ping
--- Netstat
--- NS Look Up
--- Trace Route
--- Reset Network
--- Use Open DNS - Temporary
- Timeshift Path Manager
-- USB
- Time Update
- OPKG Update + Upgrade
- Persian HD Project By Persian Prince - After Update
-- Fix Spinner
-- Fix Boot Logo
-- Fix Ajax Loader
-- Fix WebIF - Xtrend
-- Fix WebIF - Vuplus
-- Fix Remote Pictures - Xtrend
-- Fix Remote Pictures - VuPlus
-- Fix Remote Pictures - DreamBox
-- Fix Enigma2 Settings - Xtrend
-- Fix Enigma2 Settings - VuPlus
-- Fix Enigma2 Settings - DreamBox
Backup/Restore
- Enigma2 Settings
-- Restore
-- Backup
-- Backup With Date
-- USB
-- HDD
- Restore Skin.XML Backup
- Restore Language Backup
Channel - Settings Downloader
- RR Settings
- Dona Settings
- Likra Settings
- Cyrus Settings
- Rytec Settings
- Cajton Settings
- Vhannibal Settings
- Remove Channels - Settings
-- Remove Settings
-- Remove Channels
-- Reset Factory Defaults
- Data Channels Converter (Sky 19.2E)
Satellites-Terrestrial XML Downloader
- Clone
- Gemini
- SatXML
- SatHunter
- SatLoader
- FastSatFinder
- By Persian Prince
- DVB-T Official
- DVB-T By Persian Prince
Persian Tools For Persian People
- Persian Weather
- Tehran Traffic Map
- Persian Language Adder (Translated By Persian Prince)
Cleaner
- USB
- HDD
- Temp
- Key
Installer
- USB
- HDD
- Temp
File Extractor
- IPK
- NFI
- ZIP
- RAR
- TAR.GZ
Font Changer (DejaVuSans 2.33) - Supports 40 Fonts
- Bold Font
- Normal Font
- Read Me Before Do Anything !
Default Channel Audio Configuration
- English
- Persian
About Prince's Panel
- Informations
- Last Server Update
File Hashes
CRC32: 15F2C5FD
MD5: F7995992F5D51123A5F978AB3DCA9666
SHA-1: 67F0E36476D511B2C99250D1C380ADBACB831820
ChangeLogs
- "SHA1Sum Check" added
- "Kernel Informations" added
- "Installed Packages Informations" added
- "unzip" binary updated
- 3 needed libs added
- some install/uninstall problems fixed
- plugin.pyo updated
- some "Shell Scripts" updated
All 1.x , 2.x , 3.x , 4.x , 5.x , 6.x Versions Are Outdated/Unsupported
Please Remove Them From EveryWhere , Thanks In Advance
Isn't It Nice That "Persian Prince" Always Brings New Features For You ?
Feel Free To Contact Me
You Can Provide Direct Links For Settings , Satellites.XML , ...
I Will Add Them To The Next Version
Good Luck
Script Manager
- Swap Manager
- Mount Manager
-- USB
-- HDD
-- Mount
-- Format
-- UnMount
- Update Modules
- Delete Crash Logs
-- Size Check
-- MD5Sum Check
-- SHA1Sum Check
-- USB
-- HDD
-- USB
-- HDD
-- USB
-- HDD
-- Date
-- Swap
-- System
-- UpTime
-- Activity
-- Host Name
-- Process List
-- File Systems
-- Kernel Version
-- CPU
-- MAC
-- Memory
-- Free Space
-- Free Memory
-- Kernel Modules
-- HDD Performance
--- HDD Status
--- HDD Temperature
--- Ping
--- Netstat
--- NS Look Up
--- Trace Route
--- Reset Network
-- USB
- Time Update
-- Fix Spinner
-- Fix Boot Logo
-- Fix Ajax Loader
Backup/Restore
- Enigma2 Settings
-- Restore
-- Backup
-- Backup With Date
-- USB
-- HDD
- RR Settings
- Dona Settings
- Likra Settings
- Cyrus Settings
- Rytec Settings
- Cajton Settings
-- Remove Settings
-- Remove Channels
- Clone
- Gemini
- SatXML
- SatHunter
- SatLoader
- FastSatFinder
- By Persian Prince
- DVB-T Official
- Persian Weather
Cleaner
- USB
- HDD
- Temp
- Key
Installer
- USB
- HDD
- Temp
File Extractor
- IPK
- NFI
- ZIP
- RAR
- TAR.GZ
- Bold Font
- Normal Font
- English
- Persian
- Informations
File Hashes
CRC32: 15F2C5FD
ChangeLogs
Good Luck
