Problem A850B (Avermedia Volar HD)
numind
I recently posted in BH 2.0.1 thread about problems with this usb stick, just works in vu+ ultimo and solo2, I tried to power with external usb hub but nothing, after fw seconds of use when tune other channel it appears PAT error, or even tune different channel... I detected fail from BH 2.0.9 version I use last image always.
If you need logs or somethign tell me how to get and I will show here. Thx
angelofsky1980
BlackHole Driver Specialist
Follow instructions on thread http://www.vuplus-community.net/board/threads/usb-tuner-howto-report-problems.621/
numind
I tested this A850B dvb usb with other images and even dont detect it, this usb is full shit, BH is the only image able to detect and work for a while, now I have 4 avermedia volar hd pro and 1 avermedia volar green hd stuck...
I am going to install last BH 2.1.0.1 in solo and will capture logs, would be great to patch this shit dvb
numind
cted
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 64, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 59, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Success! Registering the characther device  success with 0
blackhole initialised
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ALSA device list:
  No soundcards found.
TCP cubic registered
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
EBI CS0: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000001
B4: NandSelect=40000101, nandConfig=55042200, chipSelect=0
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=55042200
Block size=00020000, erase shift=17
NAND Config: Reg=55042200, chipSize=128 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
BrcmNAND mfg ec f1 Samsung K9F1G08U0A 128MB on CS0
Found NAND on CS0: ACC=d3000000, cfg=55042200, flashId=ecf10095, tim1=4232222d, tim2=00000d94
BrcmNAND version = 0x0200 128MB @00000000
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 2.0 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0xFF for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0xFF for chip on CS0
nand_read_bbt: Bad block at 0x001e0000
nand_read_bbt: Bad block at 0x00940000
nand_read_bbt: Bad block at 0x02400000
nand_read_bbt: Bad block at 0x024c0000
nand_read_bbt: Bad block at 0x02600000
Creating 7 MTD partitions on "brcmnand.0":
0x000000000000-0x000007400000 : "rootfs"
usb 1-1: new high speed USB device number 2 using ehci-brcm
0x000007400000-0x000007800000 : "kernel"
0x000007800000-0x000007c00000 : "boot"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: max. sequence number:      0
UBI: volume 0 ("rootfs") re-sized from 524 to 910 LEBs
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            116 MiB
UBI: number of good PEBs:        923
UBI: number of bad PEBs:        5
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 923
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 1/0
UBI: image sequence number:  1196632056
UBIFS: parse sync
UBI: background thread "ubi_bgt0d" started, PID 37
UBIFS: start fixing up free space
UBIFS: free space fixup complete
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  114151424 bytes (111476 KiB, 108 MiB, 899 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 208k freed
procmk_init
dvb_bcm7325: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vusolo)
bcm7325: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (BCM7335 FE)...
[MPVR]: >> misc_pvr_init
input: dreambox remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[LCD]:power led off
[LCD]:bm730_dbox_lcd_write_data
[LCD]:vfd reply success
[CI]: registered ci0
[CI]: registered ci1
[DFP]: registered dbox fp
[DFP]:max9597_Shutdown data = 0x80
[SC]: registered sci0
system_time_set wakeup mode get
[LCD]:bm730_dbox_lcd_write_read_data len: 8
[LCD]:rtc data received 4
system_time_set wakeup mode get 0xc4
udevd (105): /proc/105/oom_adj is deprecated, please use /proc/105/oom_score_adj instead.
WARNING: You are using an experimental version of the media stack.
    As the driver is backported to an older kernel, it doesn't offer
    enough quality for its usage in production.
    Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
    Custom Black Hole build
usbcore: registered new interface driver dvb_usb_it913x
it913x: Chip Version=02 Chip Type=9135
it913x: Remote propriety (raw) mode
it913x: Dual mode=0 Tuner Type=38
it913x: Unknown tuner ID applying default 0x60
usb 1-1: dvb_usb_v2: found a 'Avermedia A835B(1835)' in cold state
usb 1-1: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
it913x: FRM Starting Firmware Download[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
it913x: FRM Firmware Download Completed - Resetting Device
it913x: Firmware Version 52887808[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0
usb 1-1: dvb_usb_v2: found a 'Avermedia A835B(1835)' in warm state
usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (Avermedia A835B(1835))
it913x-fe: ADF table value    :00
it913x-fe: Crystal Frequency :12000000 Adc Frequency :20250000 ADC X2: 01
it913x-fe: Tuner LNA type :60
usb 1-1: DVB: registering adapter 1 frontend 0 (Avermedia A835B(1835)_1)...
usb 1-1: dvb_usb_v2: 'Avermedia A835B(1835)' successfully initialized and connected
UBI: scrubbed PEB 493 (LEB 0:486), data moved to PEB 803
NET: Registered protocol family 10
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
DVB: registering adapter 0 frontend 0 (Avermedia A835B(1835)_1)...
eth0: no IPv6 routers present
[LCD]:dbox_lcd_open
[LCD]:dbox_lcd_ioctl cmd : 4117
[LCD]: unknown cmd 0x1015
[DFP]:dbox_fp_open
[CI]:ci_dev_open
[CI]:Opening A GPIO's for 7325 platform
[CI]:Opening A GPIO's for 7325 platform....done
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:Opening B GPIO's for 7325 platform
[CI]:Opening B GPIO's for 7325 platform....done
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[CI]:NEXUS_Remux_Start
[CI]:>>close_mpod tuner:0
[CI]:remux stop
[CI]:get_remux_startcnt count : 0
[CI]:get_remux_startcnt() count : 0
[CI]:>>close_mpod tuner:1
[CI]:remux stop
[DFP]:dbox_fp_open
[DFP]:dbox_fp_ioctl cmd : 0
[DFP]:dbox_fp_ioctl cmd : 256
[DFP]:dbox_fp_release
[DFP]:scart_select_tvvideotype TV = 0
[DFP]:max9597_fast_blanking data = 0x0
[DFP]:max9597_enable_output data = 0x6
[DFP]:scart_select_screentype aRatio = 1
[DFP]:max9597_slow_blanking data = 0x3
[DFP]:scart_select_tvout aTVOutType = 2
[DFP]:scart_select_screentype aRatio = 2
[DFP]:max9597_slow_blanking data = 0x1
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -2079572496
[DFP]:dbox_fp_ioctl cmd : 7
[DFP]:dbox_fp_ioctl FP_IOCTL_GET_VCR
attempt to access beyond end of device
mtdblock6: rw=0, want=2049, limit=2048
mtdblock6: rw=0, want=2052, limit=2048
UDF-fs: No partition found (1)
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 1  0
[VID]: VIDEO_PLAY 1  5 2
[VID]: VIDEO_SLOWMOTION 0    1
[VID]: VIDEO_FAST_FORWARD 0    1
[AUD]: AUDIO_SET_BYPASS_MODE 34
[AUD]: DDP proc_get_ac3 0 passthrough : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0af987c
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
[VID]: VIDEO_STOP 1  1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 audio_passthrough_spdif : 0
[VID]: VIDEO_PLAY 1  2 2
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xc0af981c
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_STOP 1
Module                  Size  Used by    Tainted: P
nfsd                  93418 11
exportfs                3544  1 nfsd
ipv6                  302875 10
it913x_fe              30581  1
ext2                  53069  0
dvb_usb_it913x          8753  2
dvb_usb_v2            12936  1 dvb_usb_it913x
bh_dvb_core            84266  1 dvb_usb_v2
brcmfb                  1127  2
dvb_bcm7325          4850247 23 brcmfb
procmk                  1397  1 dvb_bcm7325
T:  Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 1
B:  Alloc=  0/900 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 1.10 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0001 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ohci_hcd
S:  Product=Broadcom STB OHCI
S:  SerialNumber=ohci_hcd
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=  0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub  ) Sub=00 Prot=00 Driver=hub
E:  Ad=81(I) Atr=03(Int.) MxPS=  2 Ivl=255ms
T:  Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=12  MxCh= 1
T:  Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 1
B:  Alloc=  0/800 us ( 0%), #Int=  0, #Iso=  0
D:  Ver= 2.00 Cls=09(hub  ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=1d6b ProdID=0002 Rev= 3.01
S:  Manufacturer=Linux 3.1.1 ehci_hcd
S:  Product=Broadcom STB EHCI
S:  SerialNumber=ehci_hcd
E:  Ad=81(I) Atr=03(Int.) MxPS=  4 Ivl=256ms
T:  Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#=  1 Spd=480  MxCh= 1
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  2 Spd=480  MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs=  1
P:  Vendor=07ca ProdID=1835 Rev= 2.00
S:  Manufacturer=AVerMedia TECHNOLOGIES, Inc.
S:  Product=A835B
S:  SerialNumber=306741700253
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=00 Prot=00 Driver=dvb_usb_it913x
E:  Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E:  Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
NIM Socket 0:
    Type: DVB-S2
    Name: BCM7325 DVB-S2 NIM (internal)
    Frontend_Device: 0
NIM Socket 1:
    Type: DVB-T
    Frontend_Device: 1
numind
I am testing dvb usb with BH 2.0.3 and seems stable, just 5 min yet, but in case this version would work, maybe would be possible to use this driver for newest images?
numind
By the way, dvb stick is A835B, dont know why I was confused with model....so please edit title with: Avermedia Volar HD pro A835B
And sorry for too much posts, but love BH and want it ultra stable-updated...
angelofsky1980
You must update your image to latest avaiable and retry the detect of your USB DVB dongle.
numind
ok but I can assure that works stable with 2.0.3, today I will do same tests with last 2.1.0.1 but I did detect same problems with that image. Only vissionet with chip RTL2832U works fine
numind
New log from BH 2.1.0.1
UsbTuner v0.3.12
128kB, 8-way, linesize 128 bytes.
Writing ErrCtl register=00800000
Readback ErrCtl register=00800000
L2 cache parity protection enabled
Memory: 106156k/262144k available (4799k kernel code, 155988k reserved, 1118k data, 208k init, 0k highmem)
NR_IRQS:128
Measuring MIPS counter frequency...
Detected MIPS clock frequency: 332 MHz (166.497 MHz counter)
Calibrating delay loop... 220.16 BogoMIPS (lpj=110080)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
PCI2.3->SDRAM window: 512 MB
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.24.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Registering unionfs 2.5.11 (for 3.1.10)
NTFS driver 2.1.30 [Flags: R/W].
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 207
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
loop: module loaded
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:1d:ec:07:53:f9)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
brcm-pm: enabling usb clocks
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 63, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ALSA device list:
B4: NandSelect=00000101, nandConfig=55042200, chipSelect=0
After: NandSelect=40000100, nandConfig=55042200
B4: NandSelect=40000100, nandConfig=55042200, chipSelect=0
brcmnand_scan: B4 nand_select = 40000100
brcmnand_scan: After nand_select = 40000100
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x024e0000
nand_read_bbt: Bad block at 0x05f60000
nand_read_bbt: Bad block at 0x06560000
UBI: max. sequence number:      634
UBI: number of good PEBs:        925
UBI: number of bad PEBs:        3
UBI: total number of reserved PEBs: 925
UBI: max/mean erase counter: 3/0
UBI: image sequence number:  1375679804
UBIFS: parse sync
UBIFS: file system size:  114405376 bytes (111724 KiB, 109 MiB, 901 LEBs)
procmk_init
Hotplug - status.connected 0
[LCD]: registered
[LCD]:power led off
udevd (106): /proc/106/oom_adj is deprecated, please use /proc/106/oom_score_adj instead.
    Use it with care.
[LCD]:dbox_lcd_open
[DFP]:dbox_fp_open
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:NEXUS_Remux_Start CI0 0 0
[CI]:remux stop
[CI]:remux stop
[DFP]:dbox_fp_open
[AUD]: AUDIO_SET_MIXER -2069570064
[CI]:ci_dev_release
[CI]:ci_dev_release
[LCD]:dbox_lcd_open
[DFP]:dbox_fp_open
[CI]:ci_dev_open
[CI]:ci1_dev_open
[CI]:remux stop
[CI]:remux stop
[DFP]:dbox_fp_open
[DFP]:max9597_fast_blanking data = 0x1
[AUD]: AUDIO_SET_MIXER -2068980240
[AUD]: DDP downmix 0 state : 0
[AUD]: AUDIO_CONTINUE 1 1 aph=0xc0cf167c
nfsd                  93418 11
it913x_fe              30581  1
ext2                  53069  0
dvb_usb_it913x          8721  2
dvb_usb_v2            13879  1 dvb_usb_it913x
bh_dvb_core            84166  1 dvb_usb_v2
brcmfb                  1127  2
dvb_bcm7325          5432257 27 brcmfb
ipv6                  302875 10
S:  Product=A835B
NIM Socket 0:
    Type: DVB-S2
    Frontend_Device: 0
NIM Socket 1:
    Type: DVB-T
    Frontend_Device: 1
Still testing dont know if it fails..
numind
it fails again!!!, I even replaced drivers from 2.0.3 but same situation, also drivers seems the same version because of size.
angelofsky1980
The driver exchange process it's not a good idea because they can be different internally and maintain the same size.
The last report from the latest image avaiable is sufficient to determine the possibility to implement the support of your device.
