I did the same but couldn't find a way to now upgrade the FGPA as I can't access the FGPA plugin with a local .dat file or neither download from the internet.
how did you get it working?
THANKS
Try (Option A)
Using USB memory stick ( unzip directly to USB, if U wish)
1. Download the file named TS_PRO.dat_FPGA_4.5.zip attached to this post and unzip it.
2. Copy the file TS_PRO.dat into USB memory stick.
3. Attach USB memory stick to your box and restart. (or restart GUI)
4. Goto FPGA plugin menu.
5. Select the data file in USB memory stick and start 'Upgrade'.
6. Restart your box.
This good way set by Mito
the issue is that the box doesn't boot so I can't go to any menu :-(
