I had a strange problem whith recordings on my vuplus box. I searched the internet on scrambled, stutter, haperende etc....but found no solution to the problem. For those who encounter the same problem....a description of, and a solution to, the problem:
The problem:
When playing back a recorded program, the playback suffered from faltering stuttered playback. I copied the file to my PC and when I played it on my PC the same problem persists....So it is a recording issue. I Connected a USB disk, and then recorded a program. Still the same problem.
I installed blackhole, OpenPLI, and original image of vuplus 3.0. Still the same problem. But when I installed an old original 1.6 image of vuplus, the problem did not occur.
I installed the latest firmware(FPGA TS_PRO.dat). The terms firmware and image are quite often confused. But this offered no solution.
The Solution:
Eventually, I logged in the vu+ box. Something I should have done much earlier. Checked the load on the box with 'top' and noticed that when a recording was started, the load rises very quickly. The process that gave the load was mount.ntfs-3g.
Checked my USB disk, which I had previously used to test whether it was a harddisk problem. And this turned out to also be formatted with NTFS.
So I formatted the hdd with ext4 and the problem was solved. Guess it's a ntfs driver issue.
Hope this helps people suffering the same problem.
Regards,
Itiseye
The problem:
The Solution:
Regards,
Itiseye
