Problem mounting Sata HDD 2.5"
No I haven’t installed Fancontrol as yet! Reason is that I Haven’t used Hdd long enough to heat up
I do think that there is some sort of conflict with Hdd and my Full Backup, I did read that some people were having issues and had to disconnect the hdd in order to get a clean re-flash
This weekend I will start from scratch and see what Vu+solo2 likes and dislikes
Regards
Fan has to be on! I've noticed, that only watching one HD program sometimes rise up speed of my fan (fancontrol2, default settings for 4 wire config).
It's not inside for fun, but it's up to you, if you want to shorten the life of your box PSU.
I found only one problem with Solo2 HDD.
A backup folder /vuplus/solo2 created a problems during USB flashing (but not on my Duo).
All systems go!!!! what it looks like here is that Hdd wants to be master!
at first I flashed BH Image mounted media/usb and univerval then tried to mount hdd and came up with the same problem!
I then restarted the procedure, but this time I mounted the Hdd first (media/hdd) and so far no problems, in fact it's running like a well oiled engine.
thanks to all participants in this topic
