Problem solo with 3.0.9
allu
I have a problem
When I install version 3.0.9 in the flash of my vu Solo, I can hardly do anything because the Vu becomes very slow since the flash is almost full.
That's why I have to use 2.0.9 old version
Could you help me?
Really? And why do you think it has been CLEARLY written in the download page that it is not advised to install this image (for such an obsolete box like the Solo) in flash?
It is highly recommended to install it in multiboot and not in flash.
And it would be also good to install in flash a lighter image like OBH and then, if you really want BH, install it in OMB.
That's why I'm looking for advice
With the 2.0.9 in flash can I install the 3.0.9 in the pen in multiboot or a newer one?
If it was so simple, I would tell you. If you install such an old image in flash, it will be its openMultiboot plugin to manage the other images! It's like using old leaded petrol with the modern cars.
Actually, if I'm not wrong, BH 209 did not even know what Openmultiboot plugin was. At the time, there was only Meoboot...
