Problem to find channels
e_gon
Hello,
I got a wierd problem when Im trying to find any transponders for my cable-tv with my Solo SE
I am running OpenBlackHole-0.1-vusolose_usb_nightly_20150525
When Im trying to search for channels it says
"failedpll_read_adap" and "failedfe_read_adap"
And after a while it says "error searching transponder"
Are my tuner broken?
Missing drivers for the tuner adapter?
Matrix10
PLL
http://en.wikipedia.org/wiki/Phase-locked_loop
PLL error means translated into plain language
that is a HW defect or you trying to make scanning beyond the scope of the PLL.
(outside of the band that support tuner)
First, check tuner configuration.
and if Ok then
I recommend scanning with the original image from VU +
and if the same error then there is probably a defective tuner.
Mick12334
Moderator
Is this your first time setting it up, or have you had it running with a different image?
Beaten to it, too slow at typing.....
Matrix10
I also think it's a problem with the frequency band in which you trying to make a scan
more than HW defects of tuner.
e_gon
Thanks Matrix10!
Thats was the issue!
This config works fine for me (add to adjust the default standard)
NetworkID: 100 (add zeros after)
Start Freq: 306000
QAM 64 ang 256 should be "on" the other parts "no"
Freq Step: 1000
