problem tuner
berto001
hello I have come to ask if anyone had tuner of the problem with the saw zero recently.
because on a box of 5 zero j have 3 DEFECTIVE .
the SNR does not fix and epg does not even mark. an idea?
thank you
andyreload
I had the same problem in the past. Try fixng satellite.xml files ,otherwise increase the frequencies with snr unstable,by adding 1 at the end of frequencies .
Example : 12538 H You must do mauals searching changing only the frequencies -----------> 12539 H and you 'll have locked frequencies
